配置连线的时候, ADCDRV_1ch_Rlt2连的是Vbus;
#if (INCR_BUILD == 3) // Closed Current Loop & closed volt loop Bridgeless PFC
// Lib Module connection to "nets"
ADCDRV_1ch_Rlt1 = &Ipfc;
ADCDRV_1ch_Rlt2 = &Vbus;
ADCDRV_1ch_Rlt3 = &VL_fb;
ADCDRV_1ch_Rlt4 = &VN_fb;
但是之前的定义*ADCDRV_1ch_Rlt3 // instance #3, Vbus,这个是什么情况?
// ADC
extern volatile long *ADCDRV_1ch_Rlt1; // instance #1, IpfcA
extern volatile long *ADCDRV_1ch_Rlt2; // instance #2, IpfcB
extern volatile long *ADCDRV_1ch_Rlt3; // instance #3, Vbus
extern volatile long *ADCDRV_1ch_Rlt4; // instance #4, VL_fb
extern volatile long *ADCDRV_1ch_Rlt5; // instance #5, VN_fb
