断点设置成update view,debug自动停止
CCS5.5    FOC电流闭环的程序。debug模式下设置了断点更新GRAPH,想用GRAPH看变量的变化情况,但是debug总是出现问题,有时自动停止,有时显示处于低功耗状态,询问我是否要退出,总之无法像不设断点的时候那样正常运行。
请问是否是断点的设置影响了程序运行?(我将断点的动作设置为update view)
提示内容如下:
C28xx: Can't Run Target CPU: (Error -1041 @ 0xFFFFFF4C) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0)
C28xx: Power Failure on Target CPU
C28xx: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
