void AD_Sample(ADCSAMPLE *ADC_SmpleData)
char *msg;
memset(DMABuf1,0,256);
while(1)
//for(array_index=0;array_index<20;array_index++)
while(AdcRegs.ADCST.bit.INT_SEQ1 == 0);
AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;
DMABuf1[array_index]=((AdcRegs.ADCRESULT0)>>4);
DMABuf1[10+array_index]=((AdcRegs.ADCRESULT1)>>4);
DMABuf1[20+array_index]=((AdcRegs.ADCRESULT2)>>4);
DMABuf1[30+array_index]=((AdcRegs.ADCRESULT3)>>4);
DMABuf1[40+array_index]=((AdcRegs.ADCRESULT4)>>4);
DMABuf1[50+array_index]=((AdcRegs.ADCRESULT5)>>4);
DMABuf1[60+array_index]=((AdcRegs.ADCRESULT6)>>4);
DMABuf1[70+array_index]=((AdcRegs.ADCRESULT7)>>4);
DMABuf1[80+array_index]=((AdcRegs.ADCRESULT8)>>4);
DMABuf1[90+array_index]=((AdcRegs.ADCRESULT9)>>4);
//DMABuf1[200+array_index]=((AdcRegs.ADCRESULT10)>>4);
//DMABuf1[220+array_index]=((AdcRegs.ADCRESULT11)>>4);
array_index++;
if(array_index>=10)
Read_ADC_Result(1,ADC_SmpleData);
array_index=0;
msg="Recorder Read AD Data End \r\n";
scic_msg(msg);
break;
进入到中断,导致定时器进入不了中断
nterrupt void SEQ1INT_ISR(void) //SEQ1 ADC
char *msg;
// Insert ISR Code here
// To receive more interrupts from this PIE group, acknowledge this interrupt
// PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
// Next two lines for debug only to halt the processor here
// Remove after inserting ISR Code
//asm (" ESTOP0");
//for(;;);
//PieCtrlRegs.PIEACK.all = PIEACK_GROUP7;
//ADSample_End=1;
msg="AD SEQ1\r\n";
scic_msg(msg);
