不用FIFO。串口向DSP发送数据时,RXBUF中有数据,但是进不去中断,怎么办?求助各位大神
#include "DSP28x_Project.h" // Device Headerfile and Examples Include File
void scib_init(void);
void scib_fifo_init(void);
void scib_xmit(int a);
void configGPIO(void);
__interrupt void SCIRXINTb_ISR(void);
__interrupt void cpu_timer0_isr(void);
Uint16 LoopCount=0;
Uint16 ErrorCount;
Uint16 sci_count;
Uint16 ReceiveChar;
Uint16 Char;
unsigned char Navdata[85];
void main(void)
InitSysCtrl();
configGPIO();
DINT;
InitPieCtrl();
IER = 0x0000;
IFR = 0x0000;
InitPieVectTable();
configGPIO();
DINT;
InitPieCtrl();
IER = 0x0000;
IFR = 0x0000;
InitPieVectTable();
EALLOW;
PieVectTable.TINT0 = &cpu_timer0_isr;
PieVectTable.SCIRXINTB= &SCIRXINTb_ISR;
EDIS;
EDIS;
InitScibGpio();
scib_fifo_init(); // Initialize the SCI FIFO
scib_init(); // Initalize SCI for digital loop back
InitCpuTimers();
ConfigCpuTimer(&CpuTimer0,90,1000000);
CpuTimer0Regs.TCR.all = 0x4000;
IER = 0x101; // Enable CPU INT
PieCtrlRegs.PIECTRL.bit.ENPIE = 1;
PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
PieCtrlRegs.PIEIER9.bit.INTx3 = 1; // PIE Group 9, INT3 Receive Navigation information
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
for(;;)
void scib_init()
ScibRegs.SCICCR.all =0x0007; // 1 stop bit, No loopback
// No parity,8 char bits,
// async mode, idle-line protocol
ScibRegs.SCICTL1.all =0x0003; // enable TX, RX, internal SCICLK,
// Disable RX ERR, SLEEP, TXWAKE
ScibRegs.SCICTL2.all =0x0003;
ScibRegs.SCICTL2.bit.TXINTENA =1;
ScibRegs.SCICTL2.bit.RXBKINTENA =1;
ScibRegs.SCIHBAUD =64>>8;
ScibRegs.SCILBAUD =64 & 0x00FF;//38400波特率
ScibRegs.SCICCR.bit.LOOPBKENA =0;
ScibRegs.SCICTL1.all =0x0023; // Relinquish SCI from Reset
ScibRegs.SCITXBUF=a;
void scib_fifo_init()
ScibRegs.SCIFFTX.all=0xE040;
ScibRegs.SCIFFRX.all=0x2044;
ScibRegs.SCIFFCT.all=0x0;
EALLOW;
EALLOW;
GpioCtrlRegs.GPAMUX2.bit.GPIO20 = 0; //配置为通用I/O口
GpioCtrlRegs.GPAMUX2.bit.GPIO21 = 0;
GpioCtrlRegs.GPADIR.bit.GPIO20 = 1; //作为输出I/O
GpioDataRegs.GPADAT.bit.GPIO20 = 0;
GpioDataRegs.GPADAT.bit.GPIO21 = 1;
EDIS;
__interrupt void SCIRXINTb_ISR(void) // SCI-B-RX Receive Navigation
int i;
for (i=0;i<16;i++)
Navdata[i] = ScibRegs.SCIRXBUF.all;
for (i=0;i<16;i++)
PieCtrlRegs.PIEACK.all = PIEACK_GROUP9;
ErrorCount++;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
ErrorCount++;
// No more.
// No more.
