28035编译时错误
Other Parts Discussed in Thread: DRV8301, INSTASPIN-BLDC, CONTROLSUITE
1 catastrophic error detected in the compilation of "//".
Compilation terminated.
>> Compilation failure
gmake: *** [DRV8301_SPI.obj] Error 1
'Building file: F:/device_support/f2803x/v124/DSP2803x_common/source/DSP2803x_CodeStartBranch.asm'
'Invoking: C2000 Compiler'
"c:/ti/ccsv6/tools/compiler/c2000_6.2.7/bin/cl2000" --cmd_file="F:\soft\28035\GUI_project_InstaSPIN_BLDC\BLDC_Int_GUI_DRV83xx.c"  --silicon_version=28 -g --define=FLASH --define="DRV8301" --include_path="c:/ti/ccsv6/tools/compiler/c2000_6.2.7/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v124/DSP2803x_headers/cmd" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.3/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.3/asm" --include_path="F:/libs/math/IQmath/v15c/include" --include_path="F:/development_kits/~SupportFiles/F2803x_headers" --include_path="F:/device_support/f2803x/v124/DSP2803x_headers/include" --include_path="F:/device_support/f2803x/v124/DSP2803x_common/include" --include_path="F:/libs/app_libs/motor_control/math_blocks/v3.1" --include_path="F:/libs/app_libs/motor_control/libs/InstaSPIN-BLDC/v100/include" --diag_warning=225 --large_memory_model --unified_memory --cla_support=cla0 --cdebug_asm_data --preproc_with_compile --preproc_dependency="DSP2803x_CodeStartBranch.pp"  "F:/device_support/f2803x/v124/DSP2803x_common/source/DSP2803x_CodeStartBranch.asm"
warning: Case insensitivity of options has been deprecated; G must be written
   as g in future releases
>> WARNING: invalid compiler option ------------------------------------- (ignored)
>> WARNING: invalid compiler option ---------------------------------------- (ignored)
>> WARNING: invalid compiler option ------------------------------------------------------------------------------ (ignored)
>> WARNING: more than one source file is specified; preprocessor output will be generated for last file only
Command-line error: invalid macro undefinition: i.I_max
>> Compilation failure
gmake: *** [DSP2803x_CodeStartBranch.obj] Error 1
'Building file: F:/device_support/f2803x/v124/DSP2803x_common/source/DSP2803x_CpuTimers.c'
"c:/ti/ccsv6/tools/compiler/c2000_6.2.7/bin/cl2000" --cmd_file="F:\soft\28035\GUI_project_InstaSPIN_BLDC\BLDC_Int_GUI_DRV83xx.c"  --silicon_version=28 -g --define=FLASH --define="DRV8301" --include_path="c:/ti/ccsv6/tools/compiler/c2000_6.2.7/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v124/DSP2803x_headers/cmd" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.3/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.3/asm" --include_path="F:/libs/math/IQmath/v15c/include" --include_path="F:/development_kits/~SupportFiles/F2803x_headers" --include_path="F:/device_support/f2803x/v124/DSP2803x_headers/include" --include_path="F:/device_support/f2803x/v124/DSP2803x_common/include" --include_path="F:/libs/app_libs/motor_control/math_blocks/v3.1" --include_path="F:/libs/app_libs/motor_control/libs/InstaSPIN-BLDC/v100/include" --diag_warning=225 --large_memory_model --unified_memory --cla_support=cla0 --cdebug_asm_data --preproc_with_compile --preproc_dependency="DSP2803x_CpuTimers.pp"  "F:/device_support/f2803x/v124/DSP2803x_common/source/DSP2803x_CpuTimers.c"
