程序如下:
主程序:
#define RAMBASE 0x00002000 //总线地址,对应于片选线XZCS0and1
Uint32 *rambase;
rambase=(Uint32 *)RAMBASE;
*rambase=0x000f;
配置程序:
#include "DSP28_Device.h"
void delay(Uint16);
// InitXINTF:
// This function initializes the External Interface to a known state.
void InitXintf(void)
// Example of chaning the timing of XINTF Zones.
// Note acutal values should be based on the hardware
// attached to the zone - timings presented here are
// for example purposes.
// All Zones:
// Timing for all zones based on XTIMCLK = SYSCLKOUT/2
XintfRegs.XINTCNF2.bit.XTIMCLK = 1; // XTIMCLK = SYSCLKOUT/2
XintfRegs.XINTCNF2.bit.CLKOFF = 1; // DISABLE XCLKOUT
XintfRegs.XINTCNF2.bit.WRBUFF = 0; // NO WRITE BUFFER
XintfRegs.XINTCNF2.bit.CLKMODE = 0; // XCLKOUT = XTIMCLK
XintfRegs.XINTCNF2.bit.MPNMC=0; //enable zone7
XintfRegs.XBANK.bit.BCYC = 7;
XintfRegs.XBANK.bit.BANK = 0;
// Zone 0
// Ignore XREADY for Zone 1 accesses
// Change read access lead/active/trail timing
XintfRegs.XTIMING0.bit.USEREADY=0;
XintfRegs.XTIMING0.bit.XSIZE=3; // ALWAYS WRITE TO 11BIT
XintfRegs.XTIMING0.bit.XWRACTIVE=14;
XintfRegs.XTIMING0.bit.XWRTRAIL=6;
XintfRegs.XTIMING0.bit.XWRLEAD=6;
XintfRegs.XTIMING0.bit.XRDLEAD=6;
XintfRegs.XTIMING0.bit.XRDACTIVE=14;
XintfRegs.XTIMING0.bit.XRDTRAIL=6;
// Double lead/active/trial timing for Zone 1
XintfRegs.XTIMING0.bit.X2TIMING=0;
// Zone 1
XintfRegs.XTIMING1.bit.USEREADY = 0;
XintfRegs.XTIMING1.bit.XSIZE = 3; // ALWAYS WRITE TO 11BIT
XintfRegs.XTIMING1.bit.XWRACTIVE = 3;
XintfRegs.XTIMING1.bit.XWRTRAIL=7;
XintfRegs.XTIMING1.bit.XWRLEAD=3;
XintfRegs.XTIMING1.bit.XRDLEAD = 3;
XintfRegs.XTIMING1.bit.XRDACTIVE =7;
XintfRegs.XTIMING1.bit.XRDTRAIL = 3;
XintfRegs.XTIMING1.bit.X2TIMING=1;
// Zone 2
// Ignore XREADY for Zone 2 accesses
XintfRegs.XTIMING2.bit.USEREADY=0;
XintfRegs.XTIMING2.bit.XSIZE=3;
XintfRegs.XTIMING2.bit.XWRACTIVE=0;
XintfRegs.XTIMING2.bit.XWRTRAIL=0;
XintfRegs.XTIMING2.bit.XWRLEAD=1;
XintfRegs.XTIMING2.bit.XRDLEAD=1;
XintfRegs.XTIMING2.bit.XRDACTIVE=0;
XintfRegs.XTIMING2.bit.XRDTRAIL=0;
//no Double lead/active/trial timing for Zone 2
XintfRegs.XTIMING2.bit.X2TIMING=0;
// Zone 6
XintfRegs.XTIMING6.bit.USEREADY = 0;
XintfRegs.XTIMING6.bit.XSIZE = 3;
XintfRegs.XTIMING6.bit.XWRACTIVE = 1;
XintfRegs.XTIMING6.bit.XWRTRAIL=1;
XintfRegs.XTIMING6.bit.XWRLEAD=1;
XintfRegs.XTIMING6.bit.XRDLEAD = 1;
XintfRegs.XTIMING6.bit.XRDACTIVE =1;
XintfRegs.XTIMING6.bit.XRDTRAIL = 1;
// Double lead/active/trial timing for Zone 2
XintfRegs.XTIMING6.bit.X2TIMING=0;
delay(8);
