Cortex_M3_0: GEL Output: Memory Map Initialization Complete
Cortex_M3_0: GEL Output: Watchdog Timers Enabled
Cortex_M3_0: GEL Output: UARTs Enabled
Cortex_M3_0: Flash Programmer: Error erasing Sector N. Operation Cancelled.
Cortex_M3_0: Flash Programmer: Error erasing Flash memory.
Cortex_M3_0: Error resuming a profile counter: (Error -1066 @ 0x96) Unable to set requested breakpoint in memory. Verify that the breakpoint address is in writable memory. (Emulation package 5.0.791.0)
Cortex_M3_0: Trouble Writing Memory Block at 0x200030 on Page 0 of Length 0x6: (Error -2044 @ 0x20004648) Internal error: Requested breakpoint does not exist. Restart the application. If error persists, please report the error. (Emulation package 5.0.791.0)
Cortex_M3_0: GEL: File: C:\Documents and Settings\pyy1980\workspace_v5_2\m3_test_c.pjt\Debug\m3_test_c.pjt.out: Load failed.
Cortex_M3_0: Unable to terminate memory download: (Error -1003 @ 0x2BC5) Internal error: Invalid parameter passed to function. Restart the application. If error persists, please report the error. (Emulation package 5.0.791.0)
电源什么的应该没问题,板子都没动,这个问题经常出现,重新再LOAD也能成功。C28倒没问题。
