想要DSP28035epwm1和epwm2时钟同步,请问寄存器怎么配置?
   这里我配置的寄存器,但是仍然有相位差?还有什么地方需要配置么?
// Setup TBCLK
   EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up
   EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;        // Disable phase loading
   EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV4;       // Clock ratio to SYSCLKOUT
   EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV4;
   EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;    // Load registers every ZERO
   EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
   EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
   EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
   EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
   // Setup TBCLK
   EPwm2Regs.TBCTL.bit.CTRMODE =2;     // Count up
   EPwm2Regs.TBCTL.bit.PHSEN = 0;    // Disable phase loading
   EPwm2Regs.TBCTL.bit.PRDLD = 0;
   EPwm2Regs.TBCTL.bit.HSPCLKDIV = 0;       // Clock ratio to SYSCLKOUT
   EPwm2Regs.TBCTL.bit.CLKDIV = 0;
   EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
  // EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
   EPwm2Regs.TBCTL.bit.SWFSYNC = 1;
   EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
