在使用Experimenters Kit - Piccolo F28035开发板时,按照说明选择仿真器Texas Instruments XDS100v1 USB Emulator,连接时,提示错误:
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusb.dll'.
An error occurred while soft opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-600' (0xfffffda8).
The title is 'SC_ERR_LIB_ANY_LOCATE'.
The explanation is:
A required dynamic library could not be located.
The library isn't on the search path.
请问该如何解决,急呀,谢谢
