28034烧录问题
我用的是XDS100V3烧录28034,用的淘宝上买的XDS100V3,150元;之前小批量,4,5百烧录没啥问题,这批烧了2,3百片就有4,5十片,烧录过程中进度条无显示,或者只显示一般就出问题;有2个仿真器,都是这样,换过2台电脑也这样;是什么问题导致;这种烧坏的片子再连接再烧录就不能连接上了,咋回事??有碰到过这种问题的么?
  • “这批烧了2,3百片就有4,5十片,烧录过程中进度条无显示,或者只显示一般就出问题;” 请问有什么错误提示吗?能否给出烧录软件的相关截图?
  • 没有对应的截图,
    C28xx: Error connecting to the target: (Error -182 @ 0x0) The controller has detected a cable break that is near-to itself. The user must connect the cable/pod to the controller. (Emulation package 7.0.100.0)
    C28xx: JTAG Communication Error
    C28xx: Error occurred during flash operation: Timed out waiting for target to halt while executing FlashAPIInterface2803xV1_00.out
    C28xx: Error: (Error -1135 @ 0x8A26) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 7.0.100.0)
    C28xx: Unable to determine target status after 20 attempts
    C28xx: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
    C28xx: Error occurred during flash operation: Could not read 0x0000800A@Data: target is not connected
    C28xx: Error occurred during flash operation: Could not write 0x00008008@Data: target is not connected
    C28xx: Error occurred during flash operation: Could not write 0x00008007@Data: target is not connected
    C28xx: Error occurred during flash operation: Failed to run target while trying to execute FlashAPIInterface2803xV1_00.out
    C28xx: Error occurred during flash operation: Could not write 0x08AA7@Program: target is not connected
    C28xx: Flash Programmer: Error encountered when writing to flash memory
    C28xx: File Loader: Memory write failed: Unknown error
    C28xx: GEL: File: E:\work\jgj\demo\vfsoft\vf-3.00\Debug\vf_3.6_28034_1650_180810.out: Load failed.
    C28xx: Error connecting to the target: (Error -1015 @ 0x0) Device is not responding to the request. Device may be locked, or the debug probe connection may be unreliable. Unlock the device if possible (e.g. use wait in reset mode, and power-cycle the board). If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 7.0.100.0)
    C28xx: Flash operation timed out waiting for the algorithm to complete. Operation cancelled.
    C28xx: Power Failure on Target CPU
    C28xx: Error connecting to the target: (Error -233 @ 0x0) The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 7.0.100.0)
  • 截图没有,以上就是一系列的操作及提示,截图没截,之前烧录是在公司电脑上,没有截图跟提示了
  • C28xx: Error connecting to the target: (Error -180 @ 0x0) The controller has detected a target power loss. The user must turn-on or connect the power supply for the target. (Emulation package 7.0.100.0)
    C28xx: Error occurred during flash operation: CPU Reset error. The requested reset was aborted.
    C28xx: Error occurred during flash operation: Could not read 0x00000AEF@Data: target is not connected
    C28xx: Error occurred during flash operation: Could not read 0x00007020@Data: target is not connected
    C28xx: Error occurred during flash operation: Could not write 0x00007020@Data: target is not connected
    C28xx: GEL: File: E:\work\jgj\demo\sfsoft\wj-2.00\Debug\wj_2.00_201809.out: Load failed.
    又试了一块,提示是这个
  • 我只能根据您给出的错误提示来判断
    1 The controller has detected a cable break that is near-to itself. The user must connect the cable/pod to the controller.
    此错误表示JTAG调试器通过TDI引脚向器件发送数据,但未在TDO引脚上接收任何内容。一般是JTAG电路在JTAG调试探针附近或接近电路板时断开。建议您检查一下线路问题
    2 Device is not responding to the request. Device may be locked, or the emulator connection may be unreliable. Unlock the device if possible (e.g. use wait in reset mode, and power-cycle the board).  If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK).
    此错误是由调试探针无法与设备通信引起的。一般是芯片被锁了或者是硬件问题,您可以看一下
    3  The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 7.0.100.0)
    您可以看一下
    processors.wiki.ti.com/.../Debugging_JTAG_Connectivity_Problems
  • 你这几个现象都是已经烧坏了缘故
  • 我再屡屡;
    开始是这个,我用的是充电头来提供5v,然后1117-3.3转成3.3v,给28034供电,然后烧录,出现问题,提示如下:
    说电源缺失导致,所以换成5V,3A的开关电源给系统供5v电,1117-3.3转成3.3v,给28034供电,结果还是有坏,提示如下:
  • 已经找到问题了,是连接排线接触不良导致,晕死啊
  • 很高兴您能解决问题! 果然还是需要根据错误提示一个个排查
