TI C2000有哪些计算方面的库,是怎么分类的
Other Parts Discussed in Thread: CONTROLSUITE
我平时用28335的芯片,用了好久,平时我用到的有一个FPUfastRTS库,可以加速三角函数、除法运算。但其他的controlsuite/libs下的库了解的很少。
因此,想在此请教一下,libs文件夹里的库的总体的知识,应用范围等等。例如,CLAmath库里的函数和FPUfastRTS许多是一样的,是目标硬件不一样吗?
  • The libraries included within controlSUITE range from Fixed Point Math and Floating Point Math libraries to specialized DSP libraries as well as various Application and Utility libraries. Each library is fully documented with User Guides and provides examples when applicable. An overview of several libraries included:
    • Application Libraries
    – Motor control
    – Digital power
    – Solar
    – Software frequency response analyzer
    – PMBus
    • Math Libraries
    – IQMath
    – CLA real-time coprocessor
    – Floating point
    • DSP libraries
    – Fixed point
    – Floating point
    – VCU
    – Signal generation
    • Utilities
    – Flash API
    – Boot ROM
    – HRCAP calibration
    每个库的文件夹下都有相应的使用说明文档
  • controlSUITE中包含了很多常用的库,可以直接放在头文件调用
  • 28338的话,有IQmath,比较好用。
