如图所示,打算使用三个中断,分别是EPWM4_ISR(90kHz), CpuTimer_ISR(10 kHz), EPWM1_ISR(200 kHz, 50%, Zero Trigger), 使其中EPWM4_ISR,CpuTimer_ISR 中都嵌套 EPWM1_ISR;当只 EPWM4_ISR 嵌套EPWM1_ISR 或 只CpuTimer_ISR嵌套EPWM1_ISR,EPWM1_ISR 可正常嵌套执行;但是当EPWM4_ISR,CpuTimer_ISR,同时嵌套EPWM1_ISR时出现一个问题, EPWM1_ISR 会不时的多执行一次(图中红色箭头处)。请问为什么会这样,怎么解决这个问题?请大神指导!!!!
代码如下:
volatile Uint16 NestPIEIER;
__interrupt void epwm1_isr ( void )
// Update EPWM1 & EPWM2
// Clear INT flag for this timer
// Acknowledge this interrupt to receive more interrupts from group 3
EPwm1Regs.ETCLR.bit.INT = 1;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;
__interrupt void epwm4_isr(void)
// Set interrupt priority:
NestPIEIER = PieCtrlRegs.PIEIER3.all;
IER |= M_INT3;
IER &= M_INT3; // Set "global" priority
PieCtrlRegs.PIEIER3.all &= 0x0001; // Set "group" priority
PieCtrlRegs.PIEACK.all = 0xFFFF; // Enable PIE interrupts
__asm(" NOP");
EINT;
// Insert ISR Code here.......
// Restore registers saved:
DINT;
PieCtrlRegs.PIEIER3.all = NestPIEIER;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP3; ///2
EPwm4Regs.ETCLR.bit.INT = 1; ///2
__interrupt void CpuTimer0_isr ( void )
IER |= M_INT3;
__asm(" NOP");
EINT;
DINT;
// Acknowledge this interrupt to receive more interrupts from group 1
PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
通道2(绿):测试IO Epwm4_isr 90kHz
通道4(红): 测试IO CpuTimer0_isr 10 kHz
通道1(黄):测试IO epwm1_isr 200KHz,
通道3(蓝):epwm1 outputA
