求助 F28075仿真问题
CDS2XX 仿真器,在仿真下载完成程序后,点击“F8”运行时出现如下错误:
C28xx_CPU1: Error: (Error -1135 @ 0x8467D) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 8.0.27.9)
C28xx_CPU1: Trouble Halting Target CPU: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 8.0.27.9)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
导致无法仿真。
想问一下这是什么原因造成的? 怎么样解决?
