28027f烧写程序出现1137错误
C28xx: Trouble Writing Memory Block at 0xae5 on Page 1 of Length 0x1: (Error -1137 @ 0xAE6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE5@Data
C28xx: Trouble Writing Memory Block at 0xae6 on Page 1 of Length 0x1: (Error -1137 @ 0xAE7) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE6@Data
C28xx: Trouble Writing Memory Block at 0xae7 on Page 1 of Length 0x1: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE7@Data
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: File Loader: Memory write failed: Unknown error
C28xx: GEL: File: E:\csss\ILPFC\F2803x_FLASH\ILFC_2803x.out: Load failed.
  • “C28xx: Trouble Writing Memory Block at 0xae5 on Page 1 of Length 0x1: (Error -1137 @ 0xAE6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3)
    C28xx: Trouble Writing Memory Block at 0xae7 on Page 1 of Length 0x1: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3) ”
    Eric:
    从上面的解释上来看,芯片一致处于复位的状态,因此无法正常烧录,所以你看看芯片的复位引脚为何复位,看是不是供电有问题,或者是复位电路有问题。
  • ok,是供电的问题,有个地方虚焊了
