void
CONFIG_ADC()
// The ADC0 peripheral must be enabled for use.
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
// ADC0 is used with AIN0/1 on port E3.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
// GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3);//PE3---IN0
// 设置ADC参考电压为外部3V
ADCReferenceSet(ADC0_BASE, ADC_REF_EXT_3V);
// Enable sample sequence 3 with a processor signal trigger. Sequence 3
// will do a single sample when the processor sends a signal to start the
// conversion. Each ADC module has 4 programmable sequences, sequence 0
// to sequence 3. This example is arbitrarily using sequence 3.
ADCSequenceConfigure(ADC0_BASE, ADC_Seqnum, ADC_TRIGGER_PROCESSOR, 0);
// ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_D | ADC_CTL_CH0 |
//ADC_CTL_IE | ADC_CTL_END);
// 注意ADC的配置参数,ADC_CTL_D这个参数代表是差分输入
ADCSequenceStepConfigure(ADC0_BASE, ADC_Seqnum, 0, ADC_CTL_CH0 |
// Since sample sequence 3 is now configured, it must be enabled.
ADCSequenceEnable(ADC0_BASE, ADC_Seqnum);
// Clear the interrupt status flag. This is done to make sure the
// interrupt flag is cleared before we sample.
ADCIntClear(ADC0_BASE, ADC_Seqnum);
ADCIntEnable(ADC0_BASE, ADC_Seqnum);
ADCProcessorTrigger(ADC0_BASE, ADC_Seqnum);
ADCIntRegister(ADC0_BASE,ADC_Seqnum,ADC0_IntHandler); // 注册序列3中断 函数
ADCIntEnable(ADC0_BASE,ADC_Seqnum); // 开启adc中断
IntMasterEnable(); //开启总中断
CONFIG_ADC()
// 设置ADC参考电压为外部3V
这程序里面哪句话是定义采样时间的?或者怎么设置
