cla的汇编程序如何加入到C程序
CLA的汇编程序如下,但添加到CCS之后连接时ccs错将其识别为CPU的程序,请问编译环境如何设置(--cla_support=cla0 --float_support=fpu32已开启)或在头文件中如何定义才能让编译环境认为该程序就是CLA的汇编代码?
.cdecls C,LIST,"cla.h"
;// To include an MDEBUGSTOP (CLA breakpoint) as the first instruction
;// of each task, set CLA_DEBUG to 1. Use any other value to leave out
;// the MDEBUGSTOP instruction.
CLA_DEBUG .set 1
;// CLA code must be within its own assembly section and must be
;// even aligned. Note: since all CLA instructions are 32-bit
;// this alignment naturally occurs and the .align 2 is most likely
;// redundant
.sect "Cla1Prog"
.align 2
_Cla1Prog_Start:
_Cla1Task1:
MSTOP
MNOP
MNOP
MNOP
_Cla1T1End:
_Cla1Task2:
.if CLA_DEBUG == 1
MDEBUGSTOP
.endif
; This task logs the last NUM_DATA_POINTS
; ADCRESULT1 values in the array VoltageCLA
; When the last element in the array has been
; filled, the task will go back to the
; the first element.
; Before starting the ADC conversions, force
; Task 8 to initialize the ConversionCount to zero
MMOVZ16 MR0, @_ConversionCount ;1 变量ConversionCount存到MR0
MMOV16 MAR1, MR0, #_VoltageCLA ;2 Point to VoltageCLA[ConversionCount]
MUI16TOF32 MR0, MR0 ;3 Convert count to float32
MADDF32 MR0, MR0, #1.0 ;4 Add 1 to conversion count
MCMPF32 MR0, #NUM_DATA_POINTS.0 ;5 Compare count to max
MF32TOUI16 MR0, MR0 ;6 Convert count to Uint16
MNOP ;7 Wait till I8 to read result
MMOVZ16 MR2, @_AdcResult.ADCRESULT1 ;8 读取结果寄存器 ADCRESULT1的值存到MR2
MMOV16 *MAR1, MR2 ; 将ADC结果存到VoltageCLA
MBCNDD _RestartCount, GEQ ; If count >= NUM_DATA_POINTS
MMOVIZ MR1, #0.0 ; Always executed: load MR1 with 0
MNOP
MNOP
MMOV16 @_ConversionCount, MR0 ; If branch not taken, store current count
MSTOP
_RestartCount
MMOV16 @_ConversionCount, MR1 ; If branch taken, restart count
MSTOP
MNOP
MNOP
MNOP
_Cla1T2End:
_Cla1Task3:
MSTOP
MNOP
MNOP
MNOP
_Cla1T3End:
_Cla1Task4:
MSTOP ;;任务挂起
MNOP ;;流水线清空
MNOP
MNOP
_Cla1T4End:
_Cla1Task5:
MSTOP
MNOP
MNOP
MNOP
_Cla1T5End:
_Cla1Task6:
MSTOP
MNOP
MNOP
MNOP
_Cla1T6End:
_Cla1Task7:
MSTOP
MNOP
MNOP
MNOP
_Cla1T7End:
_Cla1Task8:
; This task initializes the ConversionCount
; to zero
MMOVIZ MR0, #0.0
MSTOP
_Cla1T8End:
_Cla1Prog_End:
.end
.include "cla.h"
