Description Resource Path Location Type
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported ADCFunctions.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_Adc.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_CodeStartBranch.asm /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_CpuTimers.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_DefaultIsr.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_EPwm.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_GlobalVariableDefs.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_PieCtrl.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_PieVect.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_SysCtrl.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported DSP2803x_usDelay.asm /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported PWMFunctions.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported backup.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported charging.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported coldstart.c /TIDA-00951-VoltageMode C/C++ Problem
--cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported main.c /TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [ADCFunctions.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [backup.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [charging.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [coldstart.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_Adc.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_CodeStartBranch.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_CpuTimers.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_DefaultIsr.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_EPwm.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_GlobalVariableDefs.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_PieCtrl.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_PieVect.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_SysCtrl.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [DSP2803x_usDelay.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [main.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: *** [PWMFunctions.obj] Error 1 TIDA-00951-VoltageMode C/C++ Problem
gmake: Target 'all' not remade because of errors. TIDA-00951-VoltageMode C/C++ Problem
