gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/CAN.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/CAN.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/CONTROL.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/CONTROL.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/CT_updown.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/CT_updown.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/DEF_GENL.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DEF_GENL.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_ADC_cal.asm', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_ADC_cal.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_CodeStartBranch.asm', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_CodeStartBranch.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_DMA.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_DMA.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_DefaultIsr.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_DefaultIsr.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_headers/source/DSP2833x_GlobalVariableDefs.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_GlobalVariableDefs.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_MemCopy.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_MemCopy.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_PieCtrl.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_PieCtrl.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_PieVect.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_PieVect.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_SysCtrl.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_SysCtrl.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/source/DSP2833x_usDelay.asm', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/DSP2833x_usDelay.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/EEPROM.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/EEPROM.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/FLASH.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/FLASH.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/IQfunction.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/IQfunction.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/KEY.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/KEY.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/MENU.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/MENU.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/MODBUS.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/MODBUS.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/PWMINT.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/PWMINT.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/SCI.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/SCI.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/TWO_PWM.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/TWO_PWM.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/TWO_PWM_CMP.C', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/TWO_PWM_CMP.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/information.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/information.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/main.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/main.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/eps_source file/system_init.c', needed by 'D:/workspace_v8/Eps28335_C/DSP2833x_project/flash/Debug/system_init.obj'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_headers/cmd/DSP2833x_Headers_nonBIOS.cmd', needed by 'all'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/cmd/F28335.cmd', needed by 'all'.
gmake: *** No rule to make target 'D:/workspace_v8/Eps28335_C/workspace_v8/Eps28335_C/DSP2833x_common/lib/IQmath_fpu32.lib', needed by 'all'.
gmake: Target 'all' not remade because of errors.
该如何解决?谢谢
