想要测量编码器的A相和B相,如何用eqep测量编码器电机的位置和速度,应该设置哪些参数。
不知您现在使用的是哪款芯片?您可以在C2000WARE内查找相关的例程,如下
C:\ti\c2000\C2000Ware_2_00_00_02\device_support\f2837xd\examples\cpu1\eqep_pos_speed\cpu01
//########################################################################### // // FILE: Example_posspeed.c // // TITLE: Pos/speed measurement using EQEP peripheral // // DESCRIPTION: // // This file includes the EQEP initialization and position and speed // calculation functions called by Eqep_posspeed.c. The position and speed // calculation steps performed by POSSPEED_Calc() at SYSCLKOUT = 200 MHz are // described below: // // 1. This program calculates: **theta_mech** // // theta_mech = QPOSCNT/mech_Scaler = QPOSCNT/4000, where 4000 is the number // of counts in 1 revolution. // (4000/4 = 1000 line/rev. quadrature encoder) // // 2. This program calculates: **theta_elec** // // theta_elec = (# pole pairs) * theta_mech = 2*QPOSCNT/4000 // // 3. This program calculates: **SpeedRpm_fr** // // SpeedRpm_fr = [(x2-x1)/4000]/T - Equation 1 // Note (x2-x1) = difference in number of QPOSCNT counts. Dividing (x2-x1) // by 4000 gives position relative to Index in one revolution. // If base RPM = 6000 rpm: 6000 rpm = [(x2-x1)/4000]/10ms - Equation 2 // = [(x2-x1)/4000]/(.01s*1 min/60 sec) // = [(x2-x1)/4000]/(1/6000) min // max (x2-x1) = 4000 counts, or 1 revolution in 10 ms // // // If both sides of Equation 2 are divided by 6000 rpm, then: // 1 = [(x2-x1)/4000] rev./[(1/6000) min * 6000rpm] // Because (x2-x1) must be <4000 (max) for QPOSCNT increment, // (x2-x1)/4000 < 1 for CW rotation // And because (x2-x1) must be >-4000 for QPOSCNT decrement, // (x2-x1)/4000>-1 for CCW rotation // speed_fr = [(x2-x1)/4000]/[(1/6000) min * 6000rpm] // = (x2-x1)/4000 - Equation 3 // // To convert speed_fr to RPM, multiply Equation 3 by 6000 rpm // SpeedRpm_fr = 6000rpm *(x2-x1)/4000 - Final Equation // // 2. **min rpm ** = selected at 10 rpm based on CCPS prescaler options // available (128 is greatest) // // 3. **SpeedRpm_pr** // SpeedRpm_pr = X/(t2-t1) - Equation 4 // where X = QCAPCTL [UPPS]/4000 rev. (position relative to Index in // 1 revolution) // If max/base speed = 6000 rpm: // 6000 = (32/4000)/[(t2-t1)/(200MHz/64)] // where 32 = QCAPCTL [UPPS] (Unit timeout - once every 32 edges) // 32/4000 = position in 1 revolution (position as a fraction // of 1 revolution) // t2-t1/(200MHz/64), t2-t1= # of QCAPCLK cycles, and // QCAPCLK cycle = 1/(200MHz/64) // = QCPRDLAT // // So: 6000 rpm = [32(200MHz/64)*60s/min]/[4000(t2-t1)] // t2-t1 = [32(200MHz/64)*60s/min]/(4000*6000rpm) - Equation 5 // = 250 CAPCLK cycles = maximum (t2-t1) = SpeedScaler // // Divide both sides by (t2-t1), and: // 1 = 32/(t2-t1) = [32(200MHz/64)*60 s/min]/(4000*6000rpm)]/(t2-t1) // Because (t2-t1) must be < 250 for QPOSCNT increment: // 250/(t2-t1) < 1 for CW rotation // And because (t2-t1) must be >-250 for QPOSCNT decrement: // 250/(t2-t1)> -1 for CCW rotation // // eed_pr = 250/(t2-t1) // or [32(200MHz/64)*60 s/min]/(4000*6000rpm)]/(t2-t1) - Equation 6 // // To convert speed_pr to RPM: // Multiply Equation 6 by 6000rpm: // SpeedRpm_fr = 6000rpm * [32(200MHz/64)*60 s/min]/[4000*6000rpm*(t2-t1)] // = [32(200MHz/64)*60 s/min]/[4000*(t2-t1)] // or [(32/4000)rev * 60 s/min]/[(t2-t1)(QCPRDLAT)]-Final Equation // // More detailed calculation results can be found in the Example_freqcal.xls // spreadsheet included in the example folder. // // This file contains source for the posspeed module // //########################################################################### // $TI Release: F2837xD Support Library v3.06.00.00 $ // $Release Date: Mon May 27 06:48:24 CDT 2019 $ // $Copyright: // Copyright (C) 2013-2019 Texas Instruments Incorporated - http://www.ti.com/ // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions // are met: // // Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer. // // Redistributions in binary form must reproduce the above copyright // notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the // distribution. // // Neither the name of Texas Instruments Incorporated nor the names of // its contributors may be used to endorse or promote products derived // from this software without specific prior written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. // $ //########################################################################### // // Included Files // #include "F28x_Project.h" #include "Example_posspeed.h" // // POSSPEED_Init - Initialize EQEP1 configuration // void POSSPEED_Init(void) { EQep1Regs.QUPRD = 2000000; // Unit Timer for 100Hz at 200 MHz // SYSCLKOUT EQep1Regs.QDECCTL.bit.QSRC = 00; // QEP quadrature count mode EQep1Regs.QEPCTL.bit.FREE_SOFT = 2; EQep1Regs.QEPCTL.bit.PCRM = 00; // PCRM=00 mode - QPOSCNT reset on // index event EQep1Regs.QEPCTL.bit.UTE = 1; // Unit Timeout Enable EQep1Regs.QEPCTL.bit.QCLM = 1; // Latch on unit time out EQep1Regs.QPOSMAX = 0xffffffff; EQep1Regs.QEPCTL.bit.QPEN = 1; // QEP enable EQep1Regs.QCAPCTL.bit.UPPS = 5; // 1/32 for unit position EQep1Regs.QCAPCTL.bit.CCPS = 6; // 1/64 for CAP clock EQep1Regs.QCAPCTL.bit.CEN = 1; // QEP Capture Enable } // // POSSPEED_Calc - Perform the position calculations // void POSSPEED_Calc(POSSPEED *p) { long tmp; unsigned int pos16bval,temp1; _iq Tmp1,newp,oldp; // // Position calculation - mechanical and electrical motor angle // p->DirectionQep = EQep1Regs.QEPSTS.bit.QDF; // Motor direction: // 0=CCW/reverse, 1=CW/forward pos16bval = (unsigned int)EQep1Regs.QPOSCNT; // capture position once // per QA/QB period p->theta_raw = pos16bval+ p->cal_angle; // raw theta = current pos. + // ang. offset from QA // // The following lines calculate // p->theta_mech ~= QPOSCNT/mech_scaler [current cnt/(total cnt in 1 rev.)] // where mech_scaler = 4000 cnts/revolution // tmp = (long)((long)p->theta_raw*(long)p->mech_scaler); // Q0*Q26 = Q26 tmp &= 0x03FFF000; p->theta_mech = (int)(tmp>>11); // Q26 -> Q15 p->theta_mech &= 0x7FFF; // // The following lines calculate p->elec_mech // p->theta_elec = p->pole_pairs*p->theta_mech; // Q0*Q15 = Q15 p->theta_elec &= 0x7FFF; // // Check an index occurrence // if(EQep1Regs.QFLG.bit.IEL == 1) { p->index_sync_flag = 0x00F0; EQep1Regs.QCLR.bit.IEL = 1; // Clear __interrupt flag } // // High Speed Calculation using QEP Position counter // // Check unit Time out-event for speed calculation: // Unit Timer is configured for 100Hz in INIT function // if(EQep1Regs.QFLG.bit.UTO == 1) // If unit timeout (one 100Hz period) { // // Differentiator // // The following lines calculate // position = (x2-x1)/4000 (position in 1 revolution) // pos16bval = (unsigned int)EQep1Regs.QPOSLAT; // Latched POSCNT value tmp = (long)((long)pos16bval*(long)p->mech_scaler); // Q0*Q26 = Q26 tmp &= 0x03FFF000; tmp = (int)(tmp>>11); // Q26 -> Q15 tmp &= 0x7FFF; newp = _IQ15toIQ(tmp); oldp = p->oldpos; if(p->DirectionQep==0) // POSCNT is counting down { if(newp>oldp) { Tmp1 = - (_IQ(1) - newp + oldp); // x2-x1 should be negative } else { Tmp1 = newp -oldp; } } else if(p->DirectionQep == 1) // POSCNT is counting up { if(newp<oldp) { Tmp1 = _IQ(1) + newp - oldp; } else { Tmp1 = newp - oldp; // x2-x1 should be positive } } if(Tmp1>_IQ(1)) { p->Speed_fr = _IQ(1); } else if(Tmp1<_IQ(-1)) { p->Speed_fr = _IQ(-1); } else { p->Speed_fr = Tmp1; } // // Update the electrical angle // p->oldpos = newp; // // Change motor speed from pu value to rpm value (Q15 -> Q0) // Q0 = Q0*GLOBAL_Q => _IQXmpy(), X = GLOBAL_Q // p->SpeedRpm_fr = _IQmpy(p->BaseRpm,p->Speed_fr); EQep1Regs.QCLR.bit.UTO=1; // Clear __interrupt flag } // // Low-speed computation using QEP capture counter // if(EQep1Regs.QEPSTS.bit.UPEVNT == 1) // Unit position event { if(EQep1Regs.QEPSTS.bit.COEF == 0) // No Capture overflow { temp1 = (unsigned long)EQep1Regs.QCPRDLAT; // temp1 = t2-t1 } else // Capture overflow, saturate the result { temp1 = 0xFFFF; } // // p->Speed_pr = p->SpeedScaler/temp1 // p->Speed_pr = _IQdiv(p->SpeedScaler,temp1); Tmp1 = p->Speed_pr; if (Tmp1>_IQ(1)) { p->Speed_pr = _IQ(1); } else { p->Speed_pr = Tmp1; } // // Convert p->Speed_pr to RPM // if(p->DirectionQep == 0) // Reverse direction = negative { // // Q0 = Q0*GLOBAL_Q => _IQXmpy(), X = GLOBAL_Q // p->SpeedRpm_pr = -_IQmpy(p->BaseRpm,p->Speed_pr); } else // Forward direction = positive { // // Q0 = Q0*GLOBAL_Q => _IQXmpy(), X = GLOBAL_Q // p->SpeedRpm_pr = _IQmpy(p->BaseRpm,p->Speed_pr); } EQep1Regs.QEPSTS.all = 0x88; // Clear Unit position event flag // Clear overflow error flag } } // // End of file //
