CCS7.1改工程名和文件夹名之后编译不通过
Other Parts Discussed in Thread: SYSBIOS, CONTROLSUITE
大家好!
我这边原来有一个工程是通过ccs7.1( Version: 7.1.0.00016 )导入的,没改工程名和文件名之前编译没问题,之后我是这样操作的:
1、把工程从ccs7.1中线删除;
2、把工程的文件夹名字改了;
3、把该工程重新导入ccs7.1中,并改掉工程名;
4、之后编译出现了如下报错信息;
"E:\\TI\\ccsv7\\utils\\bin\\gmake" -k all
making ../src/sysbios/sysbios.aem3 ...
gmake[1]: Entering directory 'F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/src/sysbios'
gmake[1]: Nothing to be done for 'all'.
gmake[1]: Leaving directory 'F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/src/sysbios'
gmake[1]: Entering directory 'F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/Release'
'Building file: ../WattMeter_5th_M3.cfg'
'Invoking: XDCtools'
"E:/TI/xdctools_3_30_03_47_core/xs" --xdcpath="E:/TI/tirtos_c2000_2_10_01_38/packages;E:/TI/tirtos_c2000_2_10_01_38/products/bios_6_41_00_26/packages;E:/TI/tirtos_c2000_2_10_01_38/products/ipc_3_30_01_12/packages;E:/TI/tirtos_c2000_2_10_01_38/products/ndk_2_24_01_18/packages;E:/TI/tirtos_c2000_2_10_01_38/products/uia_2_00_02_39/packages;E:/TI/ccsv7/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M3 -p ti.platforms.concertoM3:F28M35H52C1 -r release -c "E:/TI/ccsv7/tools/compiler/ti-cgt-arm_16.9.1.LTS" --compileOptions "-mv7M3 --code_state=16 -me -O0 --include_path=\"E:/TI/ccsv7/tools/compiler/ti-cgt-arm_16.9.1.LTS/include\" --include_path=\"E:/TI/tirtos_c2000_2_10_01_38/products/MWare_v202a/MWare\" --include_path=\"E:/TI/tirtos_c2000_2_10_01_38/products/MWare_v202a/MWare/third_party/fatfs/src\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/App\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/BSP\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/CSP\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/Emac\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/IPCM\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/USB\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/OLED\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/Task\" --include_path=\"F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/User\" --define=ccs -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --asm_define=ccs --ual " "../WattMeter_5th_M3.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring WattMeter_5th_M3.xem3 from package/cfg/WattMeter_5th_M3_pem3.cfg ...
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/src/sysbios/sysbios.aem3 ...
Build of libraries failed.
subdir_rules.mk:12: recipe for target 'build-165169663-inproc' failed
process_begin: CreateProcess(NULL, C:\pixhawk_toolchain\toolchain\bin -C F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/src/sysbios, ...) failed.
make (e=2): 系统找不到指定的文件。
gmake: *** [F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/src/sysbios/sysbios.aem3] Error 2
error: xdc.cfg.SourceDir: "E:/TI/xdctools_3_30_03_47_core/packages/xdc/cfg/SourceDir.xs", line 184: xdc.cfg.SourceDir : Build of generated source libraries failed: exit status = 2:
js: "E:/TI/xdctools_3_30_03_47_core/packages/xdc/cfg/Main.xs", line 159: Error: Configuration failed!
gmake.exe: *** [package/cfg/WattMeter_5th_M3_pem3.xdl] Error 1
gmake.exe: *** Deleting file `package/cfg/WattMeter_5th_M3_pem3.xdl'
gmake.exe: *** [package/cfg/WattMeter_5th_M3_pem3.xdl] Deleting file `package/cfg/WattMeter_5th_M3_pem3.h'
gmake.exe: *** [package/cfg/WattMeter_5th_M3_pem3.xdl] Deleting file `package/cfg/WattMeter_5th_M3_pem3.c'
js: "E:/TI/xdctools_3_30_03_47_core/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[1]: *** [build-165169663-inproc] Error 1
gmake[1]: Leaving directory 'F:/1_Pro01_161001_NSD7D/NSD7D_CCS/test/TE9938110000_001_NSD7D-2_WM_V2.0code/TE9938110000_001_NSD7D-2_WM_V2.0_App_M3/Release'
subdir_rules.mk:9: recipe for target 'build-165169663' failed
gmake: *** [build-165169663] Error 2
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
请大家帮忙看看,谢谢了!
  • 文件夹和工程名中有没有中文的字符?
    我测试了一下,如果文件夹和工程名称都没错的话,修改这两项是不会出现报错的。
  • 您好,没有中文字符的,我试了其他RTSC工程编译也都会报这种错误了,但是不是RTSC工程是不会报这种错误了;现在我打开ccs6.0也试了一下,跟这个CCS7.1一样的,RTSC工程就会报同样错误,如下;但是原来从来都不会有这样的错误的。
    **** Build of configuration Debug for project test222 ****
    "E:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
    gmake[1]: Entering directory `F:/1_Pro04_161023_Learn_module/CCS6.0/test222/src/sysbios'
    clem3 E:/TI/tirtos_c2000_2_10_01_38/products/bios_6_41_00_26/packages/ti/sysbios/BIOS.c ...
    asmem3 E:/TI/tirtos_c2000_2_10_01_38/products/bios_6_41_00_26/packages/ti/sysbios/family/arm/m3/Hwi_asm.sv7M ...
    asmem3 E:/TI/tirtos_c2000_2_10_01_38/products/bios_6_41_00_26/packages/ti/sysbios/family/arm/m3/Hwi_asm_switch.sv7M ...
    asmem3 E:/TI/tirtos_c2000_2_10_01_38/products/bios_6_41_00_26/packages/ti/sysbios/family/arm/m3/IntrinsicsSupport_asm.sv7M ...
    asmem3 E:/TI/tirtos_c2000_2_10_01_38/products/bios_6_41_00_26/packages/ti/sysbios/family/arm/m3/TaskSupport_asm.sv7M ...
    arem3 BIOS.obj m3_Hwi_asm.obj m3_Hwi_asm_switch.obj m3_IntrinsicsSupport_asm.obj m3_TaskSupport_asm.obj ...
    gmake[1]: Leaving directory `F:/1_Pro04_161023_Learn_module/CCS6.0/test222/src/sysbios'
    'Building file: ../TMDXDOCKH52C1.c'
    'Invoking: ARM Compiler'
    "E:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="E:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="E:/ti/tirtos_c2000_2_10_01_38/products/MWare_v202a/MWare" -g --gcc --define=ccs --define=MWARE --display_error_number --diag_warning=225 --diag_wrap=off --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="TMDXDOCKH52C1.pp" --cmd_file="./configPkg/compiler.opt" "../TMDXDOCKH52C1.c"
    "E:/ti/xdctools_3_30_04_52_core/packages/xdc/cfg/global.h", line 39: fatal error #1965: cannot open source file "F:/1_Pro04_161023_Learn_module/CCS6.0/test222/Debug/configPkg/package/cfg/empty_min_pem3.h"
    1 catastrophic error detected in the compilation of "../TMDXDOCKH52C1.c".
    >> Compilation failure
    Compilation terminated.
    gmake: *** [TMDXDOCKH52C1.obj] Error 1
    'Building file: ../empty_min.c'
    "E:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="E:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="E:/ti/tirtos_c2000_2_10_01_38/products/MWare_v202a/MWare" -g --gcc --define=ccs --define=MWARE --display_error_number --diag_warning=225 --diag_wrap=off --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="empty_min.pp" --cmd_file="./configPkg/compiler.opt" "../empty_min.c"
    >> Compilation failure
    1 catastrophic error detected in the compilation of "../empty_min.c".
    gmake: *** [empty_min.obj] Error 1
    'Building file: ../empty_min.cfg'
    "E:/ti/xdctools_3_30_04_52_core/xs" --xdcpath="E:/ti/tirtos_c2000_2_10_01_38/packages;E:/ti/tirtos_c2000_2_10_01_38/products/bios_6_41_00_26/packages;E:/ti/tirtos_c2000_2_10_01_38/products/ipc_3_30_01_12/packages;E:/ti/tirtos_c2000_2_10_01_38/products/ndk_2_24_01_18/packages;E:/ti/tirtos_c2000_2_10_01_38/products/uia_2_00_02_39/packages;E:/ti/ccsv6/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M3 -p ti.platforms.concertoM3:F28M35H52C1 -r release -c "E:/ti/ccsv6/tools/compiler/arm_5.1.6" --compileOptions "-mv7M3 --code_state=16 --abi=eabi -me --include_path=\"E:/ti/ccsv6/tools/compiler/arm_5.1.6/include\" --include_path=\"E:/ti/tirtos_c2000_2_10_01_38/products/MWare_v202a/MWare\" -g --gcc --define=ccs --define=MWARE --display_error_number --diag_warning=225 --diag_wrap=off --gen_func_subsections=on --ual " "../empty_min.cfg"
    configuring empty_min.xem3 from package/cfg/empty_min_pem3.cfg ...
    making F:/1_Pro04_161023_Learn_module/CCS6.0/test222/src/sysbios/sysbios.aem3 ...
    process_begin: CreateProcess(NULL, C:\pixhawk_toolchain\toolchain\bin -C F:/1_Pro04_161023_Learn_module/CCS6.0/test222/src/sysbios, ...) failed.
    gmake: *** [F:/1_Pro04_161023_Learn_module/CCS6.0/test222/src/sysbios/sysbios.aem3] Error 2
    error: xdc.cfg.SourceDir: "E:/TI/xdctools_3_30_04_52_core/packages/xdc/cfg/SourceDir.xs", line 184: xdc.cfg.SourceDir : Build of generated source libraries failed: exit status = 2:
    js: "E:/TI/xdctools_3_30_04_52_core/packages/xdc/cfg/Main.xs", line 159: Error: Configuration failed!
    xdctools_3_30_04_52_core\gmake.exe: *** [package/cfg/empty_min_pem3.xdl] Error 1
    xdctools_3_30_04_52_core\gmake.exe: *** Deleting file `package/cfg/empty_min_pem3.xdl'
    xdctools_3_30_04_52_core\gmake.exe: *** [package/cfg/empty_min_pem3.xdl] Deleting file `package/cfg/empty_min_pem3.h'
    xdctools_3_30_04_52_core\gmake.exe: *** [package/cfg/empty_min_pem3.xdl] Deleting file `package/cfg/empty_min_pem3.c'
    js: "E:/TI/xdctools_3_30_04_52_core/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    gmake: *** [configPkg/linker.cmd] Error 1
    gmake: Target `all' not remade because of errors.
  • 文件夹名字修改导致工程中记录的调用文件路径下文件找不到了 编译错误
    举例子:如你下载controlSUITE 安装完成后直接用CCS打开例程没问题,但是你将例程拷贝到其他地方打开编译不了
    就是找不到工程属性下配置的搜索路径的文件了
