问题一:
.sect "b0_dcsm_otp_z1_pswdlock"
; .long 0xFFFFFFFF ;Z1OTP_PSWDLOCK
;;.long 0xFFFFFFFF ;Reserved
在使用280049C芯片的DCSM模块进行芯片加密时,将上面代码取消注释,加入代码后会导致在烧录过程中突然中断,并报出一下故障(使用的是CCSV8.3.1版本以及18.1.4编译器和32位电脑),cmd文件就是用的例程中的。
C28xx_CPU1: GEL Output:
Memory Map Initialization Complete
C28xx_CPU1: GEL Output: ... DCSM Initialization Start ...
C28xx_CPU1: GEL Output: ... DCSM Initialization Done ...
C28xx_CPU1: Error during Flash programming (Flash algorithm returned error code). Operation cancelled.
C28xx_CPU1: File Loader: Memory write failed: Unknown error
C28xx_CPU1: GEL: File: E:\DVR-CODE\DVRSlaverLock\Debug\DVRSlaverLock.out: Load failed.
将以上代码注释后可以将代码(这里说的代码指加密单独的代码)烧录到芯片中,会导致正常代码不会运行(之前已经烧录,且烧录加密代码时没有进行擦除),只有带仿真器才可以正常运行,但之前没烧录加密代码时是可以正常运行的(重新上电后也可以正常运行),以下是我在f28004x_dcsm_z1otp.asm文件中的配置情况(可以正常烧录的代码配置),f28004x_dcsm_z2otp.asm文件没有配置:
.sect "b0_dcsm_otp_z1_linkpointer"
.long 0x1FFFFFFF ;B0_Z1OTP_LINKPOINTER1
.long 0x1FFFFFFF ;B0_Z1OTP_LINKPOINTER2
.long 0x1FFFFFFF ;B0_Z1OTP_LINKPOINTER3
.sect "b0_dcsm_otp_z1_gpreg"
; .long 0xFFFFFFFF ;Z1OTP_BOOTPIN_CONFIG
; .long 0xFFFFFFFF ;Z1OTP_GPREG2
; .long 0xFFFFFFFF ;Reserved
.sect "b0_dcsm_otp_z1_crclock"
; .long 0xFFFFFFFF ;Z1OTP_CRCLOCK
.sect "b0_dcsm_otp_z1_bootctrl"
; .long 0xFFFFFFFF ;Z1OTP_BOOTDEF_LOW
; .long 0xFFFFFFFF ;Z1OTP_BOOTDEF_HIGH
.sect "b0_dcsm_zsel_z1"
.long 0xFFFFFFFF ;B0_Z1OTP_EXEONLYRAM
.long 0xFFFFFFFF ;B0_Z1OTP_EXEONLYSECT
.long 0xFFFFF666 ;B0_Z1OTP_GRABRAM 0xFFFFF666
.long 0xFFFFFE66 ;B0_Z1OTP_GRABSECT 0xFFFFFE66
.long 0x58534C4C ;B0_Z1OTP_CSMPSWD0 (LSW of 128-bit password)
.long 0x47556953 ;B0_Z1OTP_CSMPSWD1
.long 0x16071217 ;B0_Z1OTP_CSMPSWD2
.long 0x091543F1 ;B0_Z1OTP_CSMPSWD3 (MSW of 128-bit password)
.sect "b1_dcsm_otp_z1_linkpointer"
.long 0x1FFFFFFF ;B1_Z1OTP_LINKPOINTER1
.long 0x1FFFFFFF ;B1_Z1OTP_LINKPOINTER2
.long 0x1FFFFFFF ;B1_Z1OTP_LINKPOINTER3
.sect "b1_dcsm_zsel_z1"
.long 0xFFFFFFFF ;B1_Z1OTP_EXEONLYSECT
.long 0xFFFFFE66 ;B1_Z1OTP_GRABSECT
.long 0x58534C4C ;Reserved
.long 0x47556953 ;Reserved
.long 0x16071217 ;Reserved
.long 0x091543F1 ;Reserved
问题二:
在遇到问题一后,经过查阅TI论坛,我得出结论就是CCS或者编译器版本过低,但是对于32位系统的电脑CCSV8.3.1和18.1.4编译器已经为顶配。于是我换了一个64位电脑使用CCSV10版本以及20.2.0的最新编译器并在f28004x_dcsm_z1otp.asm文件中的代码如下:
.long 0xFFFF6666 ;B0_Z1OTP_GRABRAM
.long 0x66666666 ;B0_Z1OTP_GRABSECT
.long 0x66666666 ;B1_Z1OTP_GRABSECT
在烧录加密软件过程中会报出以下故障:
C28xx_CPU1: Error during Flash Programming. Address 0x00078010, Data 0x0000E000, FMSTAT 0x00000030
C28xx_CPU1: GEL: File: E:\My Project\DVR\DVRSlaverLock\Debug\DVRSlaverLock.out: Load failed.
求大神给个解决方案
尝试一下更改参数默认值:
.long 0xFFFFFFFF ;Z1OTP_PSWDLOCK .long 0xFFFFFFFF ;Reserved .sect "b0_dcsm_otp_z1_crclock" .long 0xFFFFFFFF ;Z1OTP_CRCLOCK .long 0xFFFFFFFF ;Reserved
改成:
.long 0xfb7fffff ;Z1-PSWDLOCK
.long 0x7fffffff ;Reserved
.long 0x4bffffff ;Z1-CRCLOCK
.long 0x3fffffff ;Reserved
您好,感谢您提供方案。按照您的提示,我也做了尝试,但是在烧录结束后还是会导致我烧录到芯片内部的代码停止运行(使用32位电脑以及CCSV8.3.1和编译器18.1.4),但是我又用64位电脑以及CCSV10和编译器20.2.0进行测试,烧录过程中会报出如下错误:
C28xx_CPU1: Error during Flash Verification. Address 0x00078019, Expected 0x00009FFF, Read 0x0000FFFF
C28xx_CPU1: GEL: File: E:\workspace_v10\DVRSlaverLock\Debug\DVRSlaverLock.out: Load failed.
于是我将报错的对应位置按照以上期望值改过来,如下:
.sect "b0_dcsm_otp_z1_P0"
.long 0xfb7fffff ;Z1OTP_PSWDLOCK
.long 0x4bffffff ;Z1OTP_CRCLOCK
.long 0xFFFF9FFF ;Reserved
.long 0xFFFFFFFF ;Z1OTP_GPREG3
.long 0xFFFFFFFF ;Z1OTP_BOOTCTRL
其中,上面标红位置原来的例程中没有,是我后加的(我认为这个是寻址的,需要都进行配置,于是将所有地址位置补全了),也对应改了cmd文件如下:
MEMORY
PAGE 0 :
/* BANK0 */
B0_DCSM_OTP_Z1_P0 : origin = 0x78000, length = 0x000020
B0_DCSM_OTP_Z2_P0 : origin = 0x78200, length = 0x000020
B0_DCSM_ZSEL_Z1_P0 : origin = 0x78020, length = 0x000010
B0_DCSM_ZSEL_Z2_P0 : origin = 0x78220, length = 0x000010
/* BANK1 */
B1_DCSM_OTP_Z1_P0 : origin = 0x78400, length = 0x000020
B1_DCSM_OTP_Z2_P0 : origin = 0x78600, length = 0x000020
B1_DCSM_ZSEL_Z1_P0 : origin = 0x78420, length = 0x000010
B1_DCSM_ZSEL_Z2_P0 : origin = 0x78620, length = 0x000010
SECTIONS
/* BANK0 */
b0_dcsm_otp_z1_P0 : > B0_DCSM_OTP_Z1_P0 PAGE = 0
b0_dcsm_otp_z2_P0 : > B0_DCSM_OTP_Z2_P0 PAGE = 0
b0_dcsm_zsel_z1 : > B0_DCSM_ZSEL_Z1_P0 PAGE = 0
b0_dcsm_zsel_z2 : > B0_DCSM_ZSEL_Z2_P0 PAGE = 0
/* BANK1 */
b1_dcsm_otp_z1_P0 : > B1_DCSM_OTP_Z1_P0 PAGE = 0
b1_dcsm_otp_z2_P0 : > B1_DCSM_OTP_Z2_P0 PAGE = 0
b1_dcsm_zsel_z1 : > B1_DCSM_ZSEL_Z1_P0 PAGE = 0
b1_dcsm_zsel_z2 : > B1_DCSM_ZSEL_Z2_P0 PAGE = 0
但是报出来的故障还是没变,如下:
于是我将以下部分注释掉
; .long 0xFFFF9FFF ;Reserved
; .long 0xFFFFFFFF ;Z1OTP_GPREG3
; .long 0xFFFFFFFF ;Z1OTP_BOOTCTRL
但是又报出不同的故障,如下:
C28xx_CPU1: Error during Flash Programming. Address 0x00078210, Data 0x0000E010, FMSTAT 0x00000030
是不是我之前调试的时候最开始烧录了一个值,就固定了,需要换一块板子?
这个有参考的,因为我们公司之前用过2837xD的,也做过相应的加密,可以正常使用的。我刚开始就是按照我们公司之前做的2837xD的加密代码做的,然后按照280049C的寄存器和2837xD不一样的地方相应更改,但是就是有问题,烧录不进去,一直报以下故障:
后来我继续调试,并查找资料,看这个问题怎么解决,于是在一个连接里面找到了一种方式,链接为https://e2echina.ti.com/question_answer/microcontrollers/c2000/f/56/p/176131/576686#pi58711=2
但按照他的方式,我也遇到了相同的问题,可以烧录进去了,但是会使原来在板子里面的正式代码无法运行,用仿真器烧录(填写正确密码后)是可以正常烧录的(烧录成功后,代码正常运行),但是重新上电后就不会代码不会正常运行(通过板子上的一个灯判断的),而且看门狗似乎也没有复位,导致代码停止运行。我又换了最高版本的CCSV10以及64位电脑和编译器20.2.0,于是就出现了上面我提出的问题,而且还报出了具体位置的问题:
后来我有查找C2000里面是否有有关280049C的DCSM模块相关例程,于是看到TI员工说在C:\ti\c2000\C2000Ware_3_01_00_00\driverlib\f28004x\examples\led里面有例程,我又在这个例程的基础上更改了相关寄存器的配置,用64位电脑(最高版本的CCS和编译器)进行烧录,可以烧录进去,但是还是会导致正式代码不运行(换了块新板,之前没有烧过加密代码的)。
您好,请问为什么加了您给的这段代码:
有时候烧录代码就会报出以下故障,一个是CCSV8.3.1报的,一个是CCSV10报的
C28xx_CPU1: Trouble Halting Target CPU: (Error -1156 @ 0x0) Device may be
operating in low-power mode. Do you want to bring it out of this mode? Choose
'Yes' to force the device to wake up and retry the operation. Choose 'No' to
retry the operation without waking the device. (Emulation package 8.1.0.00012)
C28xx_CPU1: Error: (Error -1135 @ 0x0) The debug probe reported an error. Confirm
debug probe configuration and connections, reset the debug probe, and retry the
operation. (Emulation package 8.1.0.00012)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before
disconnecting. There may still be breakpoint op-codes embedded in program
memory. It is recommended that you reset the emulator before you connect and
reload your program before you continue debugging
C28xx_CPU1: GEL: Error while executing OnTargetConnect(): Could not write
0x0005F412@Data: target is not connected
at *((int *) 0x5F412)=0x0003 [f280049c.gel:83]
at OnTargetConnect()
1156的报错可能是硬件电源方面会有问题,1135的报错一般是芯片被锁之后会有这么报错。
你这边有试过更换JTAG进行烧写吗?程序中,如果加密部分的密码改成全F(即不加密状态),烧写的时候会报错吗?烧写完程序能否正常运行?
另外,你使用的应该是自己设计的板子?之前有成功烧写的经历吗?
user6341694 说:看到TI员工说在C:\ti\c2000\C2000Ware_3_01_00_00\driverlib\f28004x\examples\led里面有例程,我又在这个例程的基础上更改了相关寄存器的配置
具体更改的是哪些寄存器?还是只是修改了密码?
您好,我这边没有试过更换JTAG进行烧写。在CCS的properties-Debug-Flash Settings中更改密码时会报如下错误(有复位后解锁失败):
C28xx_CPU1: Warning: Failed unlocking device (zone 1) after reset.
C28xx_CPU1: GEL: File: E:\DVR-CODE\DVR\DVRSlaverLock\Debug\DVRSlaverLock.out: Load failed.
在程序中更改密码时,会报如下错误:
烧写成功时(前提是只烧写Zone1,且将以下区域注释掉),正式代码不运行了。
我怀疑是我第一次烧写进去的值和现在的不一样,我再换块板子试下。
我们正式代码时已经调试完了的,现在才开始加密,之前正式代码都是没有问题的,项目接近尾声,所以要加密。是自己设计的板子。
因为例程刚打开都是将默认值注释了的,而且cmd文件里面都是有type = DSECT的,所以更改代码的时候要把注释的默认值清除注释,并且按照自己的代码更改寄存器的值以及密码。具体寄存器如下:
.long 0xFB7FFFFF ;Z1OTP_PSWDLOCK
.long 0x7FFFFFFF ;Reserved
.long 0x4BFFFFFF ;Z1OTP_CRCLOCK
.long 0x3FFFFFFF ;Reserved
.long 0x55555555 ;B0_Z1OTP_GRABRAM
.long 0x55555555 ;B0_Z1OTP_GRABSECT
.long 0xFFFFFFFF;B0_Z1OTP_CSMPSWD0 (LSW of 128-bit password)
.long 0x47FFFFFF;B0_Z1OTP_CSMPSWD1 按照原来的默认值0x47FFFFFF更改后面的FFFFFF
.long 0xFFFFFFFF;B0_Z1OTP_CSMPSWD2
.long 0xFFFFFFFF;B0_Z1OTP_CSMPSWD3 (MSW of 128-bit password)
.long 0x55555555 ;B1_Z1OTP_GRABSECT
你好,不知道你的问题进展如何?
目前我还是不确定你的问题所在,隐约感觉到可能是硬件方面或者是OTP的问题,但是我对DCSM模块并不怎么熟悉,如果问题还是存在的话建议你直接去E2E英文论坛咨询一下这个情况,最好将工程打包附上,方便论坛工程师测试。
TI 诚邀您参加全新设计的产品页面测试,参加测试即可享有 TI 购物 9 折优惠码,点击加入 EP产品页面测试报名,名额有限。感谢您的参与!
