我在调试双核的blinky程序时,在connect Target时,M3进入"0x1001566",C28进入"0x3ff7ed" 。
而且分别有警告
Cortex_M3_0: Flash Programmer: Warning: The configured device (F28M35H50C1), does not match the detected device (F28M36P63C2). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx_0: Flash Programmer: Warning: The configured device (F28M35H50C1), does not match the detected device (F28M36P63C2). Flash Programming operations could be affected. Please consider modifying your target configuration file.
双核从来没有在flash中跑起来过
M3Debug下可以点亮灯,但似乎带不起来C28
拨动开关应该是正确的,不知道为什么会出现这种现象?
