为什么我的CCS工程,编译选项中找不到C2000 Hex Utility呢?
看网上的帖子说通过C2000 Hex Utility来编译产生hex文件和bin文件,如下图所示为网上说的C2000 Hex Utility的位置,但是打开我自己建立的工程编译选项里面却没有这个选项呢? 这是我电脑里面工程的编译选项,里面找不到C2000 Hex Utility,要怎么添加这个C2000 Hex Utility编译选项?
  • 您可以在下面的网页搜索 Hex utility options
    software-dl.ti.com/.../ccs_project-management.html
    The Hex Utility can be enabled and invoked as part of the build in CCS. By default, the Hex Utility is disabled for a new CCS project. Once enabled, there are several options available. Refer to the Assembly Language Tools Users Guides for details on the options supported by the Hex Conversion Utility.
    Hex utility flags can also be added or removed directly via the Edit Flags button.
    另外您现在的CCS版本是多少?您可以尝试在您给出的第一个图片的最上方输入 hex 来搜索一下
