基于DSP28377D的官方给的三相Vienna'整流的程序单步仿真时程序指针不安顺序执行
    /*offset165 = ((float32) (VREF165_FB))*ADC_PU_SCALE_FACTOR;*/
    iL1Meas = (((float32)(IL1_ADC_READ1+IL1_ADC_READ2+IL1_ADC_READ3+IL1_ADC_READ4))*ADC_PU_SCALE_FACTOR*0.25 - iL1MeasOffset )*2.0;
    iL2Meas = (((float32)(IL2_ADC_READ1+IL2_ADC_READ2+IL2_ADC_READ3+IL2_ADC_READ4))*ADC_PU_SCALE_FACTOR*0.25 - iL2MeasOffset )*2.0;
    iL3Meas = (((float32)(IL3_ADC_READ1+IL3_ADC_READ2+IL3_ADC_READ3+IL3_ADC_READ4))*ADC_PU_SCALE_FACTOR*0.25 - iL3MeasOffset )*2.0;
    v1Meas = (((float32)(V1_ADC_READ1+V1_ADC_READ2+V1_ADC_READ3+V1_ADC_READ4))*ADC_PU_SCALE_FACTOR*0.25 - v1MeasOffset )*2.0;
    v2Meas = (((float32)(V2_ADC_READ1+V2_ADC_READ2+V2_ADC_READ3+V2_ADC_READ4))*ADC_PU_SCALE_FACTOR*0.25 - v2MeasOffset )*2.0;
    v3Meas = (((float32)(V3_ADC_READ1+V3_ADC_READ2+V3_ADC_READ3+V3_ADC_READ4))*ADC_PU_SCALE_FACTOR*0.25 - v3MeasOffset )*2.0;
    vBusPMMeas = (((float32)(VBUSPM_ADC_READ1+VBUSPM_ADC_READ2+VBUSPM_ADC_READ3+VBUSPM_ADC_READ4))*ADC_PU_SCALE_FACTOR*0.25 )*VDCBUS_MAX_SENSE/VAC_MAX_SENSE;
    vBusMNMeas = (((float32)(VBUSMN_ADC_READ1+VBUSMN_ADC_READ2+VBUSMN_ADC_READ3+VBUSMN_ADC_READ4))*ADC_PU_SCALE_FACTOR*0.25 )*VDCBUS_MAX_SENSE/VAC_MAX_SENSE;
  1) vBusPMMeas = m_VBusPMMeas*vBusPMMeas + b_VBusPMMeas; // y= mx+ b equation used to reduce offset and gain error
  2)  vBusMNMeas = m_VBusMNMeas*vBusMNMeas + b_VBusMNMeas;
  3)  vBusMeas= vBusPMMeas+vBusMNMeas;
   4) vBusHalfMeas = (vBusMeas)*0.5;
    // clamp the vBusHalfMeas before dividing to avoid NaN
    vBusHalfMeas = (vBusHalfMeas<0.2)?0.2:vBusHalfMeas;
问题描述:
理论仿真时程序指针应该时从1)>2)>3)>4),这个顺序执行但实际仿真过程中不安上述执行,感觉程序指针乱跑,一会跑到4)一会跑到1)一会跑到函数外面,之后又跑到函数里面。给人感觉就是乱跑。以上没有条件编译。不要给我解释有条件编译导致的。
