PWM_INIT_MACRO(1,2,3,pwm1) 这个语句是什么意思
// Initialize PWM module
pwm1.PeriodMax = SYSTEM_FREQUENCY*1000000*T/2; // Prescaler X1 (T1), ISR period = T x 1
pwm1.HalfPerMax=pwm1.PeriodMax/2;
pwm1.Deadband = 2.0*SYSTEM_FREQUENCY; // 120 counts -> 2.0 usec for TBCLK = SYSCLK/1
无传感器控制里的,请问最后一句什么意思
  • 您可以看一下它的定义,主要是用于模块初始化
    #define PWM_INIT_MACRO(ch1,ch2,ch3,v)										\
    	     /* Setup Sync*/													\
             (*ePWM[ch1]).TBCTL.bit.SYNCOSEL = 0;       /* Pass through*/		\
    		 (*ePWM[ch2]).TBCTL.bit.SYNCOSEL = 0;       /* Pass through*/		\
    		 (*ePWM[ch3]).TBCTL.bit.SYNCOSEL = 0;       /* Pass through*/		\
             /* Allow each timer to be sync'ed*/								\
             (*ePWM[ch1]).TBCTL.bit.PHSEN = 1;									\
             (*ePWM[ch2]).TBCTL.bit.PHSEN = 1;									\
             (*ePWM[ch3]).TBCTL.bit.PHSEN = 1;									\
             /* Init Timer-Base Period Register for EPWM1-EPWM3*/				\
             (*ePWM[ch1]).TBPRD = v.PeriodMax;									\
             (*ePWM[ch2]).TBPRD = v.PeriodMax;									\
             (*ePWM[ch3]).TBPRD = v.PeriodMax;									\
             /* Init Timer-Base Phase Register for EPWM1-EPWM3*/				\
             (*ePWM[ch1]).TBPHS.half.TBPHS = 0;									\
             (*ePWM[ch2]).TBPHS.half.TBPHS = 0;									\
             (*ePWM[ch3]).TBPHS.half.TBPHS = 0;									\
             /* Init Timer-Base Control Register for EPWM1-EPWM3*/				\
             (*ePWM[ch1]).TBCTL.all = PWM_INIT_STATE;							\
    		 (*ePWM[ch2]).TBCTL.all = PWM_INIT_STATE;							\
    		 (*ePWM[ch3]).TBCTL.all = PWM_INIT_STATE;							\
             /* Init Compare Control Register for EPWM1-EPWM3*/					\
             (*ePWM[ch1]).CMPCTL.all = CMPCTL_INIT_STATE;						\
             (*ePWM[ch2]).CMPCTL.all = CMPCTL_INIT_STATE;						\
             (*ePWM[ch3]).CMPCTL.all = CMPCTL_INIT_STATE;						\
             /* Init Action Qualifier Output A Register for EPWM1-EPWM3*/		\
             (*ePWM[ch1]).AQCTLA.all = AQCTLA_INIT_STATE;						\
             (*ePWM[ch2]).AQCTLA.all = AQCTLA_INIT_STATE;						\
             (*ePWM[ch3]).AQCTLA.all = AQCTLA_INIT_STATE;						\
             /* Init Dead-Band Generator Control Register for EPWM1-EPWM3*/		\
             (*ePWM[ch1]).DBCTL.all = DBCTL_INIT_STATE;							\
             (*ePWM[ch2]).DBCTL.all = DBCTL_INIT_STATE;							\
             (*ePWM[ch3]).DBCTL.all = DBCTL_INIT_STATE;							\
             /* Init Dead-Band Generator for EPWM1-EPWM3*/						\
             (*ePWM[ch1]).DBFED = v.Deadband;									\
             (*ePWM[ch1]).DBRED = v.Deadband;									\
             (*ePWM[ch2]).DBFED = v.Deadband;									\
             (*ePWM[ch2]).DBRED = v.Deadband;									\
             (*ePWM[ch3]).DBFED = v.Deadband;									\
             (*ePWM[ch3]).DBRED = v.Deadband;									\
             /* Init PWM Chopper Control Register for EPWM1-EPWM3*/				\
             (*ePWM[ch1]).PCCTL.all = PCCTL_INIT_STATE;							\
             (*ePWM[ch2]).PCCTL.all = PCCTL_INIT_STATE;							\
             (*ePWM[ch3]).PCCTL.all = PCCTL_INIT_STATE;							\
             EALLOW;                       /* Enable EALLOW */					\
             /* Init Trip Zone Select Register*/								\
             (*ePWM[ch1]).TZSEL.all = TZSEL_INIT_STATE;							\
             (*ePWM[ch2]).TZSEL.all = TZSEL_INIT_STATE;							\
             (*ePWM[ch3]).TZSEL.all = TZSEL_INIT_STATE;							\
             EDIS;                         /* Disable EALLOW*/
  • 谢谢,请问这个是在哪个文件里找到的,请发一下路径or出处
  • 您可以右键点击 PWM_INIT_MACRO,选择 open declaration 就可以找到了
