280025c FLASH下载报错
这是下载FLASH报错的内容
C28xx_CPU1: Error writing the init algorithm.Unable to read the Flash content correctly. Make sure the device is properly powered as per the datasheet spec (Recommended Operating Conditions). Flash Plugin failed to initialize the FMC. Operation cancelled.
C28xx_CPU1: File Loader: Memory write failed: Unknown error
C28xx_CPU1: GEL: File: D:\280025C\adc_ex1_soc_software\CPU1_FLASH\adc_ex1_soc_software.out: Load failed.
RAM需要屏蔽 Device_cal(); 才能正常工作
