LAUNCHXL-F280049C: 调试程序的时候仿真器断开
Part Number: LAUNCHXL-F280049C
CCS10.3
最近调试程序的仿真器总是莫名其妙的断开,错误如下:
C28xx_CPU1: JTAG Communication Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.3.0.00042)
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
