hello
i wrote the timer code for the TMS320F28035 controller.when i try to executing the code in simulator my time timer is not running(i.e the counter is not changing)
i also checked my timer configuration that is correct.even i debug the example code also still the timer is not running.is there any possibility that the timer counter wont increase in simulator mode? its really very urgent for me could you please give me some suggestions
thanks in advance
regards
cva d
