您好,我这边需要一个测试报告,关于元器件的故障率。例如F28388D芯片工作的情况下,每小时出现故障的概率是多少呢?
类似这种信息,我一般在哪可以查找到呢?
特来请教
感谢
类似这种信息,我一般在哪可以查找到呢?
特来请教
感谢
您可以看一下下面的文档是否对您有所帮助
https://www.ti.com/lit/an/sprabx4b/sprabx4b.pdf
This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement. Electro-migration is the primary failure mechanism being modeled.
