Part Number: TMS320F28388D
我们用Ti的芯片28388时候,主要是在CPU1和CM这两个核的通讯上面碰到问题比较多
下载的一对例子ipc_ex1_basic_c28x1和ipc_ex1_basic_cm,都是采用IPC通讯,结果发现只要发送核发送一次、接收核读取一次后,接收核始终IPC_readCommand可以读到东西
好像一个消息FLAG之类的没有清掉,读取了还有,一直有
修改如下:
//ipc_ex1_basic_c28x1修改,用来查询接收
while(1)
bool IsOK;
IsOK = IPC_readCommand(IPC_CPU1_L_CM_R, IPC_FLAG1, IPC_ADDR_CORRECTION_ENABLE,
&command, &addr, &data);
if(true == IsOK)
IswriteTrged = true;
for(i=0; i<data; i++)
writeBuf[i] = *((uint32_t *)addr + i);
IPC_sendResponse(IPC_CPU1_L_CM_R, TEST_PASS);
IPC_ackFlagRtoL(IPC_CPU1_L_CM_R, IPC_FLAG0);
IPC_clearFlagLtoR(IPC_CPU1_L_CM_R, IPC_FLAG_ALL);
//ipc_ex1_basic_cm修改,writeTrg触发发送
while(1)
if(1 == writeTrg)
IPC_sendCommand(IPC_CM_L_CPU1_R, IPC_FLAG1, IPC_ADDR_CORRECTION_ENABLE,
IPC_CMD_WRITE_MEM, (uint32_t)writeBuf, 10);
writeTrg = 0;
