Other Parts Discussed in Thread: CONTROLSUITE
Buildfile generation error occurred..
This project does not contain a buildable RTSC Configuration (.cfg) file. In order for it to build, this project must contain one RTSC Configuration file that is not excluded from build.
Build stopped..
打开工程属性,如下:
上面报错:None of the currently selected products supplies value for the Target. Please specify the Target manually, or try using a pre-3.30 version of XDCtools.
下面的“Apply and Close”按钮变暗无法应用
