Part Number: LAUNCHXL-F28379D
我在测试例程can_ex4_simple_transimt时,我加入接收数据程序后发现能发送成功就是接收不到数据?
这是main函数
void main(void)
// Initialize device clock and peripherals
Device_init();
// Initialize GPIO and configure GPIO pins for CANTX/CANRX
// on module A
Device_initGPIO();
GPIO_setPinConfig(DEVICE_GPIO_CFG_CANRXB);
GPIO_setPinConfig(DEVICE_GPIO_CFG_CANTXB);
// Initialize the CAN controllers
CAN_initModule(CANB_BASE);
// Set up the CAN bus bit rate to 500kHz for each module
// Refer to the Driver Library User Guide for information on how to set
// tighter timing control. Additionally, consult the device data sheet
// for more information about the CAN module clocking.
CAN_setBitRate(CANB_BASE, DEVICE_SYSCLK_FREQ, 500000, 20);
// Initialize the transmit message object used for sending CAN messages.
// Message Object Parameters:
// CAN Module: A
// Message Object ID Number: 1
// Message Identifier: 0x95555555
// Message Frame: Extended
// Message Type: Transmit
// Message ID Mask: 0x0
// Message Object Flags: None
// Message Data Length: 4 Bytes
CAN_setupMessageObject(CANB_BASE, TX_MSG_OBJ_ID, 0x95555555,
CAN_MSG_FRAME_EXT, CAN_MSG_OBJ_TYPE_TX, 0,
CAN_MSG_OBJ_NO_FLAGS, MSG_DATA_LENGTH);
//设置接收消息对象(加入)
CAN_setupMessageObject(CANB_BASE, 2, 0x95555556,
CAN_MSG_FRAME_EXT, CAN_MSG_OBJ_TYPE_RX, 0,
// Initialize the transmit message object data buffer to be sent
txMsgData[0] = 0x01;
txMsgData[1] = 0x23;
txMsgData[2] = 0x45;
txMsgData[3] = 0x67;
txMsgData[4] = 0x89;
txMsgData[5] = 0xAB;
txMsgData[6] = 0xCD;
txMsgData[7] = 0xEF;
// Start CAN module A operations
CAN_startModule(CANB_BASE);
// Transmit messages from CAN-A
while(1)
// Comment for infinite transmissions
//for(i = 0; i < TXCOUNT; i++)
CAN_sendMessage(CANB_BASE, TX_MSG_OBJ_ID, MSG_DATA_LENGTH, txMsgData);
DEVICE_DELAY_US(1000000);
// Poll TxOk bit in CAN_ES register to check completion of transmission
while(((HWREGH(CANB_BASE + CAN_O_ES) & CAN_ES_TXOK)) != CAN_ES_TXOK)
//接收消息轮询(加入)
if(((HWREGH(CANB_BASE + CAN_O_ES) & CAN_ES_RXOK)) == CAN_ES_RXOK)
// Get the received message
CAN_readMessage(CANB_BASE, 2, rxMsgData);
// Stop application
asm(" ESTOP0");
