Part Number: LAUNCHXL-F28069M
但是,整理后得工程编译,遇到报错:
Description Resource Path Location Type
<a href="file:/A:/TI/ccs/tools/compiler/dmed/HTML/16008.html">#16008-D</a> file "../lib/2806xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_getVersion_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA revision "C28FPU32" specified in a previous file or on the command line DSP28069M_singlemotor_lab13b C/C++ Problem
<a href="file:/A:/TI/ccs/tools/compiler/dmed/HTML/16008.html">#16008-D</a> file "../lib/2806xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setEstParams_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line DSP28069M_singlemotor_lab13b C/C++ Problem
