Other Parts Discussed in Thread: CONTROLSUITE, LAUNCHXL-F28379D, , C2000WARE
最近在按着controlSUITE内的双CPU点灯例程对LAUNCHXL-F28379D进行操作,详细操作方法见https://blog.csdn.net/qq_39432978/article/details/81566779?ops_request_misc=%257B%2522request%255Fid%2522%253A%2522162728273816780264014192%2522%252C%2522scm%2522%253A%252220140713.130102334..%2522%257D&request_id=162728273816780264014192&biz_id=0&utm_medium=distribute.pc_search_result.none-task-blog-2~all~baidu_landing_v2~default-1-81566779.first_rank_v2_pc_rank_v29&utm_term=LaunchXL-F28379D+MATLAB&spm=1018.2226.3001.4187
在最后进行launch selected configuration时,报错误。
软件版本:ccs v10
硬件:LAUNCHXL-F28379D (选择仿真器XDS100V2)
C28xx_CPU1: Trouble Writing Memory Block at 0x5f412 on Page 1 of Length 0x1: This operation is not supported by this driver
C28xx_CPU1: GEL: Error while executing OnTargetConnect(): Target failed to write 0x0005F412@Data
at *((int*) 0x5F412)=0x000F [f28379d_cpu1.gel:79]
at OnTargetConnect()
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x70204@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5FB00@Program: data is not present
C28xx_CPU1: Trouble Writing Memory Block at 0x5fb00 on Page 0 of Length 0x2: This operation is not supported by this driver
C28xx_CPU1: Error occurred during flash operation: Target failed to write 0x5FB00@Program
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x0005F800@Data: data is not present
C28xx_CPU1: Trouble Writing Memory Block at 0x5f800 on Page 1 of Length 0x2: This operation is not supported by this driver
C28xx_CPU1: Error occurred during flash operation: Target failed to write 0x0005F800@Data
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5FF00@Program: data is not present
C28xx_CPU1: Trouble Writing Memory Block at 0x5ff00 on Page 0 of Length 0x2: This operation is not supported by this driver
C28xx_CPU1: Error occurred during flash operation: Target failed to write 0x5FF00@Program
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x0005FC00@Data: data is not present
C28xx_CPU1: Trouble Writing Memory Block at 0x5fc00 on Page 1 of Length 0x2: This operation is not supported by this driver
C28xx_CPU1: Error occurred during flash operation: Target failed to write 0x0005FC00@Data
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x700B0@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x70201@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x00070202@Data: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x00070200@Data: data is not present
C28xx_CPU1: Flash Programmer: Warning: The configured device (TMS320F28379D), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F000@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F002@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F004@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F01A@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F01C@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F01E@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F020@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F040@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F042@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F044@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F05A@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F05C@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F05E@Program: data is not present
C28xx_CPU1: Error occurred during flash operation: Cannot read 0x5F060@Program: data is not present
C28xx_CPU2: Trouble Writing Memory Block at 0x5f412 on Page 1 of Length 0x1: This operation is not supported by this driver
C28xx_CPU2: GEL: Error while executing OnTargetConnect(): Target failed to write 0x0005F412@Data
at *((int*) 0x5F412)=0x000F [f28379d_cpu2.gel:75]
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x70204@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5FB00@Program: data is not present
C28xx_CPU2: Trouble Writing Memory Block at 0x5fb00 on Page 0 of Length 0x2: This operation is not supported by this driver
C28xx_CPU2: Error occurred during flash operation: Target failed to write 0x5FB00@Program
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x0005F800@Data: data is not present
C28xx_CPU2: Trouble Writing Memory Block at 0x5f800 on Page 1 of Length 0x2: This operation is not supported by this driver
C28xx_CPU2: Error occurred during flash operation: Target failed to write 0x0005F800@Data
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5FF00@Program: data is not present
C28xx_CPU2: Trouble Writing Memory Block at 0x5ff00 on Page 0 of Length 0x2: This operation is not supported by this driver
C28xx_CPU2: Error occurred during flash operation: Target failed to write 0x5FF00@Program
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x0005FC00@Data: data is not present
C28xx_CPU2: Trouble Writing Memory Block at 0x5fc00 on Page 1 of Length 0x2: This operation is not supported by this driver
C28xx_CPU2: Error occurred during flash operation: Target failed to write 0x0005FC00@Data
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x700B0@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x70201@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x00070202@Data: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x00070200@Data: data is not present
C28xx_CPU2: Flash Programmer: Warning: The configured device (TMS320F28379D), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F000@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F002@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F004@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F01A@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F01C@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F01E@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F020@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F040@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F042@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F044@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F05A@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F05C@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F05E@Program: data is not present
C28xx_CPU2: Error occurred during flash operation: Cannot read 0x5F060@Program: data is not present
