LAUNCHXL-F28379D: 想修改采样频率
Part Number: LAUNCHXL-F28379D
在adc官方例程中有一个adc_ex6_soc_continuous_dma.c ,我想修改adc采样频率,无论我怎么修改epwm采样频率都不变。希望工程师可以指点一下
// FILE:   adc_ex6_soc_continuous_dma.c
// TITLE:  ADC continuous conversions read by DMA.
//! \addtogroup driver_example_list
//! <h1> ADC Continuous Conversions Read by DMA (adc_soc_continuous_dma)</h1>
//! This example sets up two ADC channels to convert simultaneously. The
//! results will be transferred by the DMA into a buffer in RAM.
//! \b External \b Connections \n
//!  - A3 & D3 pins should be connected to signals to convert
//! \b Watch \b Variables \n
//! - \b adcADataBuffer \b: a digital representation of the voltage on pin A3\n
//! - \b adcDDataBuffer \b: a digital representation of the voltage on pin D3\n
// $TI Release: F2837xD Support Library v3.12.00.00 $
// $Release Date: Fri Feb 12 19:03:23 IST 2021 $
// $Copyright:
// Copyright (C) 2013-2021 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
// Function Prototypes
__interrupt void adcA1ISR(void);
__interrupt void dmach1ISR(void);
void configureEPWM(uint32_t epwmBase);
void configureADC(uint32_t adcBase);
void setupADCContinuous(uint32_t adcBaseuint16_t channel);
void initializeDMA(void);
void configureDMAChannels(void);
// Defines
#define RESULTS_BUFFER_SIZE     1024 //buffer for storing conversion results
                                //(size must be multiple of 16)
#define EX_ADC_RESOLUTION       12
// 12 for 12-bit conversion resolution, which supports (ADC_MODE_SINGLE_ENDED)
// Sample on single pin (VREFLO is the low reference)
// Or 16 for 16-bit conversion resolution, which supports (ADC_MODE_DIFFERENTIAL)
// Sample on pair of pins (difference between pins is converted, subject to
// common mode voltage requirements; see the device data manual)
// Globals
#pragma DATA_SECTION(adcADataBuffer"ramgs0");
#pragma DATA_SECTION(adcDDataBuffer"ramgs0");
uint16_t adcADataBuffer[RESULTS_BUFFER_SIZE];
uint16_t adcDDataBuffer[RESULTS_BUFFER_SIZE];
volatile uint16_t done;
void main(void)
    uint16_t resultsIndex;
    // Initialize device clock and peripherals
    Device_init();
    // Disable pin locks and enable internal pullups.
    Device_initGPIO();
    // Initialize PIE and clear PIE registers. Disables CPU interrupts.
    Interrupt_initModule();
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    Interrupt_initVectorTable();
    // Set up ISRs used by this example
    // ISR for ADCA INT1 - occurs after first conversion
    // ISR for DMA ch1 - occurs when DMA transfer is complete
    Interrupt_register(INT_ADCA1, &adcA1ISR);
    Interrupt_register(INT_DMA_CH1, &dmach1ISR);
    // Enable specific PIE & CPU interrupts:
    // ADCA INT1 - Group 1, interrupt 1
    // DMA interrupt - Group 7, interrupt 1
    Interrupt_enable(INT_ADCA1);
    Interrupt_enable(INT_DMA_CH1);
    // Stop the ePWM clock
    SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    // Call the set up function for ePWM 2
    configureEPWM(EPWM2_BASE);
    // Start the ePWM clock
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    // Configure the ADCA & ADCD and power it up
    configureADC(ADCA_BASE);
    configureADC(ADCD_BASE);
    // Setup the ADC for continuous conversions on channels A3 and D3
    setupADCContinuous(ADCA_BASE, 3);
    setupADCContinuous(ADCD_BASE, 3);
    // Initialize the DMA & configure DMA channels 1 & 2
    initializeDMA();
    configureDMAChannels();
    // Initialize results buffer
    for(resultsIndex = 0; resultsIndex < RESULTS_BUFFER_SIZE; resultsIndex++)
        adcADataBuffer[resultsIndex] = 0;
        adcDDataBuffer[resultsIndex] = 0;
    // Clearing all pending interrupt flags
    DMA_clearTriggerFlag(DMA_CH1_BASE);   // DMA channel 1
    DMA_clearTriggerFlag(DMA_CH2_BASE);   // DMA channel 2
    HWREGH(ADCA_BASE + ADC_O_INTFLGCLR) = 0x3U// ADCA
    HWREGH(ADCD_BASE + ADC_O_INTFLGCLR) = 0x3U// ADCD
    EPWM_forceADCTriggerEventCountInit(EPWM2_BASE, EPWM_SOC_A); // EPWM2 SOCA
    EPWM_clearADCTriggerFlag(EPWM2_BASE, EPWM_SOC_A);    // EPWM2 SOCA
    // Enable continuous operation by setting the last SOC to re-trigger
    // the first
    ADC_setInterruptSOCTrigger(ADCA_BASE, ADC_SOC_NUMBER0,    // ADCA
                               ADC_INT_SOC_TRIGGER_ADCINT2);
    ADC_setInterruptSOCTrigger(ADCD_BASE, ADC_SOC_NUMBER0,    // ADCD
    // Enable global Interrupts and higher priority real-time debug events:
    EINT;  // Enable Global interrupt INTM
    ERTM;  // Enable Global realtime interrupt DBGM
    // Start DMA
    done = 0;
    DMA_startChannel(DMA_CH1_BASE);
    DMA_startChannel(DMA_CH2_BASE);
    // Finally, enable the SOCA trigger from ePWM. This will kick off
    // conversions at the next ePWM event.
    EPWM_enableADCTrigger(EPWM2_BASE, EPWM_SOC_A);
    // Loop until the ISR signals the transfer is complete
    while(done == 0)
        __asm(" NOP");
    ESTOP0;
// adcA1ISR - This is called after the very first conversion and will disable
//             the ePWM SOC to avoid re-triggering problems.
#pragma CODE_SECTION(adcA1ISR".TI.ramfunc");
    // Remove ePWM trigger
    EPWM_disableADCTrigger(EPWM2_BASE, EPWM_SOC_A);
    // Disable this interrupt from happening again
    Interrupt_disable(INT_ADCA1);
    // Acknowledge interrupt
    Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP1);
// dmach1ISR - This is called at the end of the DMA transfer, the conversions
//              are stopped by removing the trigger of the first SOC from
//              the last.
#pragma CODE_SECTION(dmach1ISR".TI.ramfunc");
    // Stop the ADC by removing the trigger for SOC0
                               ADC_INT_SOC_TRIGGER_NONE);
    done = 1;
    Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP7);
// configureEPWM - Set up the ePWM2 module so that the A output has a period
//                 of 40us with a 50% duty. The SOCA signal is coincident with
//                 the rising edge of this.
    // Make the timer count up with a period of 40us
    HWREGH(epwmBase + EPWM_O_TBCTL) = 0x0000U;
    EPWM_setTimeBasePeriod(epwmBase, 4000U);
    // Set the A output on zero and reset on CMPA
    EPWM_setActionQualifierAction(epwmBase, EPWM_AQ_OUTPUT_A,
                                  EPWM_AQ_OUTPUT_HIGH,
                                  EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
                                  EPWM_AQ_OUTPUT_LOW,
                                  EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    // Set CMPA to 20us to get a 50% duty
    EPWM_setCounterCompareValue(epwmBase, EPWM_COUNTER_COMPARE_A, 2000U);
    // Start ADC when timer equals zero (note: don't enable yet)
    EPWM_setADCTriggerSource(epwmBase, EPWM_SOC_A, EPWM_SOC_TBCTR_ZERO);
    EPWM_setADCTriggerEventPrescale(epwmBase, EPWM_SOC_A, 1U);
    // Enable initialization of the SOCA event counter. Since we are
    // disabling the ETSEL.SOCAEN bit, we need a way to reset the SOCACNT.
    // Hence, enable the counter initialize control.
    EPWM_enableADCTriggerEventCountInit(epwmBase, EPWM_SOC_A);
// configureADC - Write ADC configurations and power up the ADC for both
//                ADC A and ADC C
    // Set ADCDLK divider to /4
    ADC_setPrescaler(adcBase, ADC_CLK_DIV_4_0);
    // Set resolution and signal mode (see #defines above) and load
    // corresponding trims.
#if(EX_ADC_RESOLUTION == 12)
    ADC_setMode(adcBase, ADC_RESOLUTION_12BIT, ADC_MODE_SINGLE_ENDED);
#elif(EX_ADC_RESOLUTION == 16)
    ADC_setMode(adcBase, ADC_RESOLUTION_16BIT, ADC_MODE_DIFFERENTIAL);
#endif
    // Set pulse positions to late
    ADC_setInterruptPulseMode(adcBase, ADC_PULSE_END_OF_CONV);
    // Power up the ADCs and then delay for 1 ms
    ADC_enableConverter(adcBase);
    // Delay for 1ms to allow ADC time to power up
    DEVICE_DELAY_US(1000);
// setupADCContinuous - setup the ADC to continuously convert on one channel
    uint16_t acqps;
    // Determine minimum acquisition window (in SYSCLKS) based on resolution
        acqps = 14// 75ns
    else //resolution is 16-bit
        acqps = 63// 320ns
    // - NOTE: A longer sampling window will be required if the ADC driving
    //   source is less than ideal (an ideal source would be a high bandwidth
    //   op-amp with a small series resistance). See TI application report
    //   SPRACT6 for guidance on ADC driver design.
    // Configure SOCs channel no. & acquisition window.
    // Trigger SCO0 from EPWM2SOCA.
    // Trigger all other SOCs from INT1 (EOC on SOC0).
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER0, ADC_TRIGGER_EPWM2_SOCA,
                 (ADC_Channel)channel, acqps);
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER1, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER2, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER3, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER4, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER5, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER6, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER7, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER8, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER9, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER10, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER11, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER12, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER13, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER14, ADC_TRIGGER_SW_ONLY,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER15, ADC_TRIGGER_SW_ONLY,
    // Configure ADCINT1 trigger for SOC1-SOC15
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER1,
                               ADC_INT_SOC_TRIGGER_ADCINT1);
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER2,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER3,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER4,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER5,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER6,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER7,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER8,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER9,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER10,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER11,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER12,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER13,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER14,
    ADC_setInterruptSOCTrigger(adcBase, ADC_SOC_NUMBER15,
    // Enable ADCINT1 & ADCINT2. Disable ADCINT3 & ADCINT4.
    ADC_enableInterrupt(adcBase, ADC_INT_NUMBER1);
    ADC_enableInterrupt(adcBase, ADC_INT_NUMBER2);
    ADC_disableInterrupt(adcBase, ADC_INT_NUMBER3);
    ADC_disableInterrupt(adcBase, ADC_INT_NUMBER4);
    // Enable continuous mode
    ADC_enableContinuousMode(adcBase, ADC_INT_NUMBER1);
    ADC_enableContinuousMode(adcBase, ADC_INT_NUMBER2);
    // Configure interrupt triggers
    ADC_setInterruptSource(adcBase, ADC_INT_NUMBER1, ADC_SOC_NUMBER0);
    ADC_setInterruptSource(adcBase, ADC_INT_NUMBER2, ADC_SOC_NUMBER15);
// initializeDMA - Initialize DMA through hard reset
    // Perform a hard reset on DMA
    DMA_initController();
    // Allow DMA to run free on emulation suspend
    DMA_setEmulationMode(DMA_EMULATION_FREE_RUN);
// configureDMAChannels - Initialize DMA ch 1 to transfer ADCA results
//                        and DMA ch 2 to transfer ADCB results
    // DMA channel 1 set up for ADCA
    DMA_configAddresses(DMA_CH1_BASE, (uint16_t *)&adcADataBuffer,
                        (uint16_t *)ADCARESULT_BASE);
    // Perform enough 16-word bursts to fill the results buffer. Data will be
    // transferred 32 bits at a time hence the address steps below.
    DMA_configBurst(DMA_CH1_BASE, 1622);
    DMA_configTransfer(DMA_CH1_BASE, (RESULTS_BUFFER_SIZE >> 4), -142);
    DMA_configMode(DMA_CH1_BASE, DMA_TRIGGER_ADCA2,
                   (DMA_CFG_ONESHOT_DISABLE | DMA_CFG_CONTINUOUS_DISABLE |
                    DMA_CFG_SIZE_32BIT));
    DMA_enableTrigger(DMA_CH1_BASE);
    DMA_disableOverrunInterrupt(DMA_CH1_BASE);
    DMA_setInterruptMode(DMA_CH1_BASE, DMA_INT_AT_END);
    DMA_enableInterrupt(DMA_CH1_BASE);
    // DMA channel 2 set up for ADCD
    DMA_configAddresses(DMA_CH2_BASE, (uint16_t *)&adcDDataBuffer,
                        (uint16_t *)ADCBRESULT_BASE);
    DMA_configBurst(DMA_CH2_BASE, 1622);
    DMA_configTransfer(DMA_CH2_BASE, (RESULTS_BUFFER_SIZE >> 4), -142);
    DMA_configMode(DMA_CH2_BASE, DMA_TRIGGER_ADCA2,
    DMA_enableTrigger(DMA_CH2_BASE);
    DMA_disableOverrunInterrupt(DMA_CH2_BASE);
    DMA_setInterruptMode(DMA_CH2_BASE, DMA_INT_AT_END);
    DMA_enableInterrupt(DMA_CH2_BASE);
// End of file
  • 你好,方便重点讲一下你是修改的哪部分代码?
  • 修改这里EPWM的周期和占空比并没有改变ADC的采样率。
                                      EPWM_AQ_OUTPUT_LOW,
