Part Number: TMS320F280049C
Other Parts Discussed in Thread: C2000WARE,
我使用C2000WARE中的PMBUS库时加入库正常但是编译后提示Description Resource Path Location Type
#10373-D library "E:/TMS320f280049C_demo/test_28004_Pmbusslave/pmbuslib/lib/F28004x_PMBus_Communications_Stack.lib" contains ELF object files which are incompatible with the TI-COFF output file. Ensure you are using the proper library. test_28004_Pmbusslave C/C++ Problem 提升库输出格式与项目不兼容,我感觉这个库可能是EABI的,请问COFF格式的库怎么得到,我查看了C2000ware好像没有coff格式的lib。
请问TI工程师有没有什么办法解决
