LAUNCHXL-F28379D: 开发板的仿真器无法正常工作
Part Number: LAUNCHXL-F28379D
在debug中运行程序一段时间后,Expressions中变量值会突然无法被观察,并且console窗口出现以下提示:
C28xx_CPU1: JTAG Communication Error: (Error -150 @ 0x0) One of the FTDI driver functions used during configuration returned a invalid status or an error. (Emulation package 9.3.0.00058)
C28xx_CPU1: Breakpoint Manager: Unable to remove requested AET job
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
