Other Parts Discussed in Thread: SYSBIOS,
你好,问:已经安装了sysbios和tirtos安装包,为什么CCS没有相关插件或刷新相关插件出错是什么原因?见下图
CCS版本:V10.3或V11, 电脑系统:W10
看了一下你的报错,感觉跟电脑本身的关系更大,是不是公司的网络有IT管控,有些文件安装被管控了没有安装成功?
1、新建sysbios typical工程编译出错,帮忙看下是什么原因?见下图
2、在你电脑上新建280049 sysbios typical完整编译ok工程给我,在这边找原因或差异,谢谢。
**** Clean-only build of configuration Debug for project prj280049_test6 ****
"D:\\Program Files\\ccs\\utils\\bin\\gmake" -k -j 8 clean -O
DEL /F "prj280049_test6.hex" "configPkg\linker.cmd" "configPkg\compiler.opt" "prj280049_test6.out"
DEL /F "main.obj"
DEL /F "main.d"
RMDIR /S/Q "configPkg\"
系统找不到指定的文件。
找不到 D:\2 sf\bios\test6\Debug\main.obj
找不到 D:\2 sf\bios\test6\Debug\main.d
系统找不到指定的文件。
Finished clean
**** Build Finished ****
**** Build of configuration Debug for project prj280049_test6 ****
"D:\\Program Files\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Building file: "../app.cfg"
Invoking: XDCtools
"D:/Program Files/xdctools_3_32_02_25_core/xs" --xdcpath="D:/Program Files/bios_6_83_00_18/packages;D:/0 tool/2 SH/CCSV11/bios/xdais_7_24_00_04/packages;D:/0 tool/2 SH/CCSV11/bios/xdais_7_24_00_04/examples;D:/Program Files/tirtos_c2000_2_16_01_14/packages;D:/Program Files/tirtos_c2000_2_16_01_14/products/tidrivers_c2000_2_16_01_13/packages;D:/Program Files/tirtos_c2000_2_16_01_14/products/bios_6_45_02_31/packages;D:/Program Files/tirtos_c2000_2_16_01_14/products/ndk_2_25_00_09/packages;D:/Program Files/tirtos_c2000_2_16_01_14/products/uia_2_00_05_50/packages;" xdc.tools.configuro -o configPkg -t ti.targets.C28_float -p ti.platforms.tms320x28:TMS320F280049 -r release -c "D:/Program Files/ccs/tools/compiler/ti-cgt-c2000_21.6.0.LTS" --compileOptions "-g" "../app.cfg"
subdir_rules.mk:12: recipe for target 'build-1983481729-inproc' failed
D:\Program Files\xdctools_3_32_02_25_core\D:/Program Files/xdctools_3_32_02_25_core/xs: error: can't create session manager: create of JVM failed
gmake[1]: *** [build-1983481729-inproc] Error 1
gmake: *** No rule to make target 'build-1983481729', needed by 'configPkg/compiler.opt'.
gmake: *** No rule to make target 'build-1983481729', needed by 'configPkg/linker.cmd'.
gmake: Target 'all' not remade because of errors.
额,所以插件出错的问题已经解决了是吗?
新建SYS/BIOS工程的问题可能要麻烦你前往英文E2E论坛去咨询一下,英文论坛有专人会负责SYS/BIOS相关问题:
你好,下面出错是什么原因?
**** Build of configuration Debug for project prj280049_test1 ****
"C:\\ti\\ccs1100\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Invoking: XDCtools
"C:/ti/ccs1100/xdctools_3_62_01_16_core/xs" --xdcpath="C:/ti/bios_6_82_01_19/packages;C:/ti/tirtos_c2000_2_16_01_14/packages;C:/ti/tirtos_c2000_2_16_01_14/products/tidrivers_c2000_2_16_01_13/packages;C:/ti/tirtos_c2000_2_16_01_14/products/bios_6_45_02_31/packages;C:/ti/tirtos_c2000_2_16_01_14/products/ndk_2_25_00_09/packages;C:/ti/tirtos_c2000_2_16_01_14/products/uia_2_00_05_50/packages;D:/liyf/bios/bios/xdais_7_24_00_04/xdais_7_24_00_04/packages;D:/liyf/bios/bios/xdais_7_24_00_04/xdais_7_24_00_04/examples;" xdc.tools.configuro -o configPkg -t ti.targets.C28_float -p ti.platforms.tms320x28:TMS320F280049 -r debug -c "C:/ti/ccs1100/ccs/tools/compiler/ti-cgt-c2000_21.6.0.LTS" --tcf --compileOptions "-g" "../app.cfg"
subdir_rules.mk:12: recipe for target 'build-1983478769-inproc' failed
xdc.tools.configuro: unknown option: --tcf
Usage: xs xdc.tools.configuro [--help]
[-v | -q]
[-@ optionsfile]
[-o outdir]
[-b config_bld | -c codegen_dir | --cb]
[-t target] [-p platform[:instance]] [-r profile]
[-Dname=value]
[-w | -x regexp]
[--rtsName pkg_name]
[--cfgArgs args_string]
[--linkTemplate linker_template]
[--pkg] [--generationOnly]
[--compileOptions compile_options_string]
[--linkOptions linker_options_string]
[--oc compiler.opt] [--ol linker.cmd]
infile.cfg
js: "C:/ti/ccs1100/xdctools_3_62_01_16_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: fatal error
gmake[1]: *** [build-1983478769-inproc] Error 1
gmake: *** No rule to make target 'build-1983478769', needed by 'configPkg/compiler.opt'.
gmake: *** No rule to make target 'build-1983478769', needed by 'configPkg/linker.cmd'.
