Build Options的编译选项卡的-pdsw225是什么意思?
在CCS3.3建立工程时,发现Build Options的编译选项卡里默认含有-pdsw225
请问-pdsw225是什么意思?
  • 楼主,该编译选项在<Optimizeing C&C++ Compiler User Guide>(SPRU514E)中描述如下:
    DIAG_WARNING num   -pdsw=num[, num2, num3...]    Treat diagnostic num as a warning
    --diag_warning=num
    Categorizes the diagnostic identified by num as a warning. To determine the numeric identifier of a diagnostic message, use the --display_error_number option first in a separate compile. Then use --diag_warning=num to recategorize the diagnostic as a warning. You can only alter the severity of discretionary diagnostics.
    楼主自己翻译一下就知道啥意思了:)
  • 末末 说:
    --diag_warning=num
    楼主自己翻译一下就知道啥意思了:)
    num是否是系统保留的?例如上面的225是什么意思?
