Part Number: TMS320F28377D
仿真器连接成功,使用在线仿真模式,cmd选择文件正确,使用官方历程,程序可以下载进去,但是点击运行时出现如下错误:
C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 8.3.0.00003)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
在该界面点击运行,出现上述错误
