在MATLAB总运行checkEnvSetup('ccsv5','F28335 eZdsp', 'setup')
CCSv5、CGT、BIOS路径设置成功,Flash Tools 2.1已经下载安装了,但是在设置路径时发现对应文件夹都是空的,求助,具体信息如下
1. Checking CCSv5 (Code Composer Studio) version
Required version: 5.0 or later
Required for : Code Generation
Your Version : 5.2.1
### Setting environment variable "TI_DIR" to "D:\Program Files\Texas Instruments\ccsv5"
2. Checking CGT (Texas Instruments C2000 Code Generation Tools) version
Required version: 5.2.1 to 6.0.2
Required for : Code generation
Your Version : 5.2.6
### Setting environment variable "C2000_CGT_INSTALLDIR" to "C:\Program Files\Texas Instruments\C2000 Code Generation Tools 5.2.6"
3. Checking DSP/BIOS (Real Time Operating System) version
Required version: 5.33.05 to 5.41.11.38
Your Version : 6.33.05.46
### Setting environment variable "CCSV5_DSPBIOS_INSTALLDIR" to "D:\Program Files\Texas Instruments\bios_6_33_05_46"
The version found for "DSP/BIOS" differs from the one used for our software validation. Use it at your own risk.
4. Checking XDC Tools (eXpress DSP Components) version
Required version: 3.16.02.32 or later
Your Version : 3.20.03.63
5. Checking Flash Tools (TMS320C28335 Flash APIs) version
Required version: 2.10
Required for : Flash Programming
Warning: Index exceeds matrix dimensions.
> In E:\MATLAB\MATLAB Production Server\R2012b\toolbox\idelink\extensions\ticcs\envchecker\checkEnvSetup_private.p>envSetup at 296
In E:\MATLAB\MATLAB Production Server\R2012b\toolbox\idelink\extensions\ticcs\envchecker\checkEnvSetup_private.p>checkEnvSetup_private at 75
In checkEnvSetup at 156
Your Version : NOT FOUND
The required version of Flash Tools is not found in E:\MATLAB\MATLAB Production Server\R2012b\bin
Following environment variable(s) required for code generation could not be set:
### "FLASH_28335_API_INSTALLDIR"
