CCS5.3关于IQ的库调用编译后有警告,这个警告怎样能消去?
在CCS5.3下面编译后提示这样关于IQmath.lib的警告,怎样才能去掉?
Description Resource Path Location Type
#16002-D build attribute vendor section TI missing in "../commonandheaders/DSP2803x_common/lib/IQmath.lib<IQ15cos.obj>": compatibility cannot be determined 2000wPR    C/C++ Problem
#16002-D build attribute vendor section TI missing in "../commonandheaders/DSP2803x_common/lib/IQmath.lib<IQ15div.obj>": compatibility cannot be determined 2000wPR    C/C++ Problem
#16002-D build attribute vendor section TI missing in "../commonandheaders/DSP2803x_common/lib/IQmath.lib<IQ15sin.obj>": compatibility cannot be determined 2000wPR    C/C++ Problem
#16002-D build attribute vendor section TI missing in "../commonandheaders/DSP2803x_common/lib/IQmath.lib<IQmathTables.obj>": compatibility cannot be determined 2000wPR    C/C++ Problem
请问下这个是有什么导致的。怎么消去?谢谢了!我上一个工程,一开始有的,后来不知道怎么就弄掉了,没有提示警告!忘记怎么设置了!
