CCS5.3.0.00090_win32关于IQmath兼容性的问题~~~!!望大虾指教~~!!
warning #16002-D: build attribute vendor section TI missing in "E:/ccs530_28015/XKDSP_zvsfb/DSP280x_common/lib/IQmath.lib<IQ15div.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "E:/ccs530_28015/XKDSP_zvsfb/DSP280x_common/lib/IQmath.lib<IQ15int.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "E:/ccs530_28015/XKDSP_zvsfb/DSP280x_common/lib/IQmath.lib<IQ24div.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "E:/ccs530_28015/XKDSP_zvsfb/DSP280x_common/lib/IQmath.lib<IQ24frac.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "E:/ccs530_28015/XKDSP_zvsfb/DSP280x_common/lib/IQmath.lib<IQ24int.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "E:/ccs530_28015/XKDSP_zvsfb/DSP280x_common/lib/IQmath.lib<IQ24mpyI32int.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "E:/ccs530_28015/XKDSP_zvsfb/DSP280x_common/lib/IQmath.lib<IQmathTables.obj>": compatibility cannot be determined
这里是我用CCS5.3.0.00090_win32编译之后提示的警告~~~!!配置应该没什么不妥~~~!只是为什么会提示无法确保上述IQ函数的兼容性呢~~!请教下,应该怎么清除上述警告,或者还是置之不理~~!?我用CCS4.2时候不会提示这些警告~~!!!
