C28xx: Failed CPU Reset
C28xx: Failed CPU Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.232.0)
C28xx: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.232.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.232.0)
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1 at (ST1&~(0x0100)) [f2812.gel:286] at C28x_Mode() [f2812.gel:38] at OnReset(1) .
C28xx: Trouble Writing Memory Block at 0x3f8000 on Page 0 of Length 0x2: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.232.0)
C28xx: GEL: File: D:\pjt\ccs5\led\Debug\led.out: Load failed.
That's the prompt. Any solution? Thank you
