28335在CCS3.3下编程使用位域的问题
我在CCS3.3下使用位域
如果这样定义的话
struct  NWBYTE0BIT
    unsigned char NC           :2;            /*Network Command*/
    unsigned char SYNCbits     :6;              /*SYNCbits Reserved */
就会有warning出现   warning: nonstandard type for a bit field
按照下面的定义就ok了
struct  NWBYTE0BIT
    unsigned int NC           :2;            /*Network Command*/
    unsigned int SYNCbits     :6;              /*SYNCbits Reserved */
    unsigned int              :8;
就这点有点不理解,是我设置的问题
还是编译器上有一些限制?
