CCS5.2中IQmath.lib不兼容
Other Parts Discussed in Thread: CONTROLSUITE
今天尝试着在CCS5.2下面建了个工程,关于IQmath的,其实就是把CCS3.3工程下面的文件拷贝到CCS5.2的工程下面,然后进行编译,然后就出现了下列问题:
warning #16002-D: build attribute vendor section TI missing in "../lib/2803x_IQmath_BootROMSymbols.lib<__Release_TMS320x2803x_boot_rom_out___IQ24div_tmp.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "../lib/2803x_IQmath_BootROMSymbols.lib<__Release_TMS320x2803x_boot_rom_out___IQ24sin_tmp.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "../lib/IQmath.lib<IQ24sinPU.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "../lib/IQmath.lib<IQ24toF.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "../lib/IQmath.lib<IQ30sinPU.obj>": compatibility cannot be determined
warning #16002-D: build attribute vendor section TI missing in "../lib/IQmath.lib<IQmathTables.obj>": compatibility cannot be determined
'Finished building target: my_IQtest.out'
查资料显示 IQmath.lib 的版本不兼容问题。别人说可以忽略这个问题!!!
但是!!!! ,不能编译,无法生成  .out  文件!!
如果可以忽略这个问题,那么要怎么设置??才能使编译器忽略这个问题???
请指点一下!
my_IQtest.zip
