我在dsp28069的epwm中断中使用查询法莱实现ad采样的即: while (AdcRegs.ADCINTFLG.bit.ADCINT1 == 0){} AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;,但当我运行程序的时候,程序只停留在在while (AdcRegs.ADCINTFLG.bit.ADCINT1 == 0){} 这行,说明ad的中断标志位没有置位,这是怎么回事,下面是我的ad模块的相应配置:
EALLOW;
AdcRegs.ADCCTL2.bit.ADCNONOVERLAP = 1;
AdcRegs.INTSEL1N2.bit.INT1E = 1; //Enabled ADCINT1
AdcRegs.INTSEL1N2.bit.INT1CONT = 0; //Disable ADCINT1 Continuous mode
AdcRegs.INTSEL1N2.bit.INT1SEL = 0x06;
AdcRegs.ADCSOC0CTL.all = 0x2806;
AdcRegs.ADCSOC1CTL.all = 0x2806; // (Sample window = ACQPS + 1)ACQPS_Value = 6
AdcRegs.ADCSOC2CTL.all = 0x2806;
AdcRegs.ADCSOC3CTL.all = 0x2806;
AdcRegs.ADCSOC4CTL.all = 0x2846; // set SOC4,5,6,7 channel select to ADCINA1,start trigger on EPWM1A
AdcRegs.ADCSOC5CTL.all = 0x2846; // (Sample window = ACQPS + 1)ACQPS_Value = 6
AdcRegs.ADCSOC6CTL.all = 0x2846;
AdcRegs.ADCSOC7CTL.all = 0x2846;
EDIS;
EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group
EPwm1Regs.ETSEL.bit.SOCASEL = 1; //计数器等于0触发一次AD转换
EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event
EPwm1Regs.ETCLR.bit.SOCA = 1;
