在CCS5.21中,使用#include "stdlib.h" ,编译报错;在"Project" - “properties” - “Include Option”中,添加了 "${workspace_loc:/${ProjName}/lib/IQmath.lib}"
再编译不会报错和警告,但不能生成.OUT,无任何提示。
你好,谢谢你的回复。之前我也已经多次Clear Project后重新Bulid ,但无用。
Console提示:
"F:/Electric_Motor_control/lib/rts2800_ml.lib", line 1: error #171: expected a declaration
"F:/Electric_Motor_control/lib/rts2800_ml.lib", line 2: error #7: unrecognized token
"F:/Electric_Motor_control/lib/rts2800_ml.lib", line 3: warning #1-D: last line of file ends without a newline
"F:/Electric_Motor_control/lib/rts2800_ml.lib", line 3: error #915: invalid character in input line
"F:/Electric_Motor_control/lib/rts2800_ml.lib", line 3: error #7: unrecognized token
"F:/Electric_Motor_control/lib/IQmath.lib", line 2: error #7: unrecognized token
"F:/Electric_Motor_control/lib/IQmath.lib", line 3: error #915: invalid character in input line
"F:/Electric_Motor_control/lib/IQmath.lib", line 3: error #7: unrecognized token
"F:/Electric_Motor_control/lib/IQmath.lib", line 3: error #19: extra text after expected end of number
是否是库文件出现问题,帮忙分析原因谢谢。
你好,我将工程已发传上来,直接编辑就会出现相关问题!麻烦帮忙分析一下!
你的工程我试过了,直接编译是会报IQmath.lib的错,由于你的.c文件没有,主函数为空,我去掉IQmath.lib文件及其相关设置,工程编译通过且生产了.out文件,但是此时还有几个关于rts2800_ml.lib的warning。由此判断你之前报错可能是因为你的应用文件中IQmath.lib的使用不正确,你可以参考下controlSUITE中的说明文件:C:\ti\controlSUITE\libs\math\IQmath\v160\doc\IQmath_Quickstart.pdf
你好!
我最近用的是C6657,不过暂时还没上板调试,但是我现在也出现添加头文件导致文件错误,我将头文件去掉,然后注释掉只剩main的空函数,还是回报错误,错误形式也不变
Building file: ../evmc665x_gpio.c' 'Invoking: C6000 Compiler' "C:/ti/ccsv6/tools/compiler/c6000_7.4.14/bin/cl6x" -mv6600 --abi=coffabi -g --include_path="C:/ti/ccsv6/tools/compiler/c6000_7.4.14/include" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="evmc665x_gpio.pp" "../evmc665x_gpio.c" "../evmc665x_gpio.c", line 1: warning #1-D: last line of file ends without a newline "../evmc665x_gpio.c", line 1: error #915: invalid character in input line "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #78-D: this declaration has no storage class or type specifier "../evmc665x_gpio.c", line 1: error #66: expected a ";" "../evmc665x_gpio.c", line 1: error #10: "#" not expected here "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #7: unrecognized token "../evmc665x_gpio.c", line 1: error #8: missing closing quote 37 errors detected in the compilation of "../evmc665x_gpio.c"这是故障代码,弄了一整天也没弄明白,求赐教
