TI FPU lib提供的算法库支持不扶持2048点 FFT
1024点是支持的,那么,支持不支持2048点FFT?
extern void CFFT_f32(CFFT_F32_STRUCT *);                // Complex FFT
extern void CFFT_f32u(CFFT_F32_STRUCT *);                 // Complex FFT, unaligned input
extern void CFFT_f32_sincostable(CFFT_F32_STRUCT *);    // Twiddle Factor Generation
extern void CFFT_f32_mag(CFFT_F32_STRUCT *);            // Complex FFT, magnitude
extern void CFFT_f32s_mag(CFFT_F32_STRUCT *);            // Complex FFT, scaled magnitude
extern void CFFT_f32_phase(CFFT_F32_STRUCT *);            // Complex FFT,    phase
extern void ICFFT_f32(CFFT_F32_STRUCT *);                // Inverse Complex FFT, aligned input
extern void RFFT_f32(RFFT_F32_STRUCT *);                // Real FFT, aligned input
extern void RFFT_f32u(RFFT_F32_STRUCT *);               // Real FFT, unaligned input
extern void RFFT_adc_f32(RFFT_ADC_F32_STRUCT *);        // Real FFT with adc input, aligned input
extern void RFFT_adc_f32u(RFFT_ADC_F32_STRUCT *);        // Real FFT with adc input, unaligned input
extern void RFFT_f32_mag(RFFT_F32_STRUCT *);            // Real FFT, magnitude
extern void RFFT_f32s_mag(RFFT_F32_STRUCT *);           // Real FFT, sclaed magnitude
extern void RFFT_f32_phase(RFFT_F32_STRUCT *);          // Real FFT, phase
extern void RFFT_f32_sincostable(RFFT_F32_STRUCT *);    // Real FFT, twiddle calculation
