Other Parts Discussed in Thread: UNIFLASH
利用XDS100V2进行烧录,在Test connection显示成功,对其程序烧录时,出现以下报错。
C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.8.0.00235)
C28xx_CPU1: Trouble Halting Target CPU: (Error -1135 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.8.0.00235)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
烧录器正常,选择正确。Uniflash可以读取Memory的数据,就是烧录程序烧录不进去,报错。如何解决?
